1 - 8 of 8 Posts
Someone please chime in and help me out.
Scored some Donahoe coilovers on eBay. They are missing the upper bolts apparently. Are these the same bolts that come on the stock setup or does anyone have a good idea how I can obtain them?
Thanks.
Different then stock.
You should be able to get some new bolts from a hardware store. Might want to give Icon a call as well and see if they have some in stock they could ship you or to at lest get the specs of the bolts used. Don't want to put something in that isn't strong enough and loose a coil over on the trail. :)
Emeritus Moderator
They should just switch out with the stock upper bolts. Those are the older DR's, you won't have to go with an aftermarket UCA with that set. That in it self will save you some money.
I called Icon because I was bidding on them as well.....congrats! They told me they were a grade 8 bolt that you can buy at any hardware store. They also told me that if you want them looked over/rebuilt, its $60 per shock.
1 - 8 of 8 Posts
