So looks like my axle seal is blown. has anyone replaced it and if so how hard was it? looked for a thread on it and came up empty. any info would be greatly appreciated.
You probably need to look over your warranty contract and ask them to show you why this repair will not be covered. The service tech, or manager, should be able to help clear this up for you to clarify if it should be covered. I wouldn't just take their word for it. Ask nicely for some clarification.I have the exact same problem, with no mods to really speak of. I purchased my 07 FJ in 08' as a Toyota certified Vehical (7 year 100M). After having a rental for two days, they call to inform me that I need a CV Axle seal and it was not covered nor will the rental be covered. The said the repair was going to cost roughly 380.
Can anyone truely confirm within the coverage where it states this is covered or not?? I sill have 20M miles / 2 years of coverage and am about to get hosed. Please help
that post was 12 months ago :lol:I have the exact same problem, with no mods to really speak of. I purchased my 07 FJ in 08' as a Toyota certified Vehical (7 year 100M). After having a rental for two days, they call to inform me that I need a CV Axle seal and it was not covered nor will the rental be covered. The said the repair was going to cost roughly 380.
WIKID
Re: driver side axle seal
First you should power wash the entire area so you don't have to work in muck
You will need to disassemble the front.
Remove tire
remove 12 mm bolt from brake line bracket on the right side of the spindle
remove 2 17 mm bolts that hld the caliper on the spindle, use bailing wire to hang up the caliper on the frame so it doesnt stretch break lines
unclip abs sensor wire from the back side of hub, unclip wire clamps holding wire and put it aside where the caliper is
remove 2, 19 mm bolts from bottom of spindle
remove center dust cap on hub.
remove pin from center and retaining washer
36 mm socket to remove large hub nut
there are 4, 17 mm bolts on the back side of the hub that come off
pull hub and dust shield
you should be able pull the spindle away from the cv axle . If you havent drained the front dif you should do this now
flat head screw driver under truck at the base of the inner cv axle housing and try to snap it out of the housing It may take a little work
It's a c clip that just snaps the axle shaft out of a groove
the seal should be right in front of the housing it probably has to be pryed out
clean area and carefully tap the new seal in with a mallet using even pressure the carefully install the axle shaft back in the housing try not to scar the new seal . It will need to click in place to ensure it's in correct
reassemble
