I recently got one of those "Jet Boil" stoves & the "Flash" model has a coffee press accessory- makes a little less than a liter if you don't let the water go to a boil- which is easy as there is a 'color change' sensor built into the neoprene insulator (which stays on the pot when it's heating) sleeve. The Jet Boil stove heats Very quickly, and packs up into it's own 'pot' including one of the smaller propane canisters as it's made for backpackers, all in all a well designed unit and the coffee press works great- a couple of minutes is about all it takes! I also picked up a GSI (?) small one liter 'teapot'- if you get one of the big mouth thermoses you can put a small amount of rice, or vegetables in them with boiling water and VERY LOOSELY put on the lid, and few hours later everything will cook, takes some experimenting to get the water to food quantities right depending on what food, size of thermos etc. But it's a neat trick- do it in the morning or at lunch & it'll be ready for later!
Cost (on SALE at REI co-op) Jet Boil 'Flash': $ 70, Coffee Press Accessory: $ 14, Fuel Canister: Jet Boil w/canister disposal 'tool' $10 (tool is re-usable-basically a 'can opener'), Fuel without the tool $ 5, GSI 'teapot if you want to do "thermos cooking" (includes a 'cup' thing) $35. Jet Boil's have a great rep., and can be used w/frying pans etc. Fuel canister with moderate use lasts about one weekend. The "Flash" model is I think the only one that works with the coffee press. The whole 'package' I bought was about $ 130 with two fuel canisters (small size).
