'Directly' usually means no fuse, so no, you want to have at least a fuse in line.
Next to that, it depends on how you want the horn to work. The factory horn has a relay and a 10A Fuse which should be plenty to power the wolo.
The factory horn should have one GRAY/BLK wire, which should be power and thats it. It grounds itself though the bolt.
