1 - 16 of 16 Posts
Total Auto Performance - Las Vegas, NV
702-979-1577 | 888-244-6166
[email protected]
Browse the entire line of EBC brake parts for your Toyota on our site. Once you have selected the parts you want, add them to the shopping cart and enter promocode
TUNDRAS
for a special discount!
EBC Brakes produce the largest range of brake pads and brake discs in the world with over 5000 part numbers for every type of moving vehicle. EBC Brakes are made in one of its two specialist factories in the UK and USA. The majority of EBC brake discs or brake rotors are also made in the UK
NEW BRAKE PAD + ROTOR PACKAGES
EBC Brake Kit - Stage 1 Street
The EBC Stage 1 Premium Street Brake Kit combines the Ultimax Pads and the Stock Replacement Rotors for the ultimate OEM pad and rotor combination
EBC Brake Kit - Stage 2 Sport
The Stage 2 Sport Kit increases your trucks stopping power and produces less brake dust than stock brakes without emptying your wallet
EBC Brake Kit - Stage 3 Truck/SUV
The EBC Stage 3 Light Truck & SUV Brake kit is perfect for your Ford Truck. This kit is popular for light to moderate towing applications and vehicles equipped with bigger wheels and tires.
EBC Brake Kit - Stage 4 Signature
The Stage 4 Kit is for those who want less dust, long life and shorter stops. Includes the ever popular truck pads - EBC Greenstuff 7000 & USR rotors
EBC Brake Kit - Stage 5 Super Street
The Stage 5 Kit matches EBC's strongest gripping truck pads with their 3GD series rotors. If brake dust isn’t a concern and you want heavy duty, high friction pads and rotors then this is your kit.
Total Automotive Performance carries the complete EBC Performance Brake Line for cars & trucks
Enter promocode
FJC
on our site for instant EBC discounts
Contact us with any questions, price inquiries, fitment checks, international shipping or just to talk truck!
702-979-1577 | [email protected]
How do drilled or slotted or drilled & slotted rotors perform off-road where dust, mud, and water are present? I got my front rotors turned, which was a mistake, as now I have pulsing in the brake pedal. I've got the TRD front pads so I'm not looking for pads at this time, but do need new rotors.
We normally do not recommend drilled rotors due to the fact that as we drive thru water which can lead to cracking and lots of debris can get logged in the holes.
EBC design is unique as their rotors are dimpled, but not drilled. This provides much more strength.
Slotted and/or dimpled rotors are recommended. In our experience, the slots help sand and other debris to exit more easily. They also keep the pad wear very even to the face of the rotor and help prevent pad buildup which leads to rotor "warping" or pedal pulsation that some have experienced. There also seems to be much more initial bite on the brakes with slotted rotors. They do cut down on pad life a bit, but when combine with aftermarket high-performance pads, the lifetime ends up being similar. Slotted rotors will cause slightly more dust, its a worthwhile tradeoff in our testing.
I'm going to change my rear brakes and rotors in the next couple of weeks. What kit would you recommend with for a 2010 Fj with a 3" lift and 33" tires with front and rear steel bumpers.
Thank you for your help
-Nick
Read some reviews online that the EBC slotted rotors make a lot of wind noise on the road. Anyone have experience with this on FJs?
-Nick
I would do a stage 5 from EBC with those larger tires. The yellow pads are really the best way to go:rocker:
might want to bump that discount up a bit....was looking for this deal earlier in the week, but didn't look hard enough apparently...so i got a stage 3 F&R through Summit Racing for only $1 more...ordered monday afternoon and received the package yesterday... just saying :D
went through you guys for my Tacoma brake swap though :D
I am interested on a set of ebc sports but some reviews say they stop the fj's quick but make noise , are these that noisy ? I like they are slotted and dimpled but I also like my ride quite.
Discussion Starter #14
Sometimes when you hit the brakes at a mid-level speed quickly, they can make a whooshing noise as air escapes out the slots. I only notice it on my truck when the windows are down and I am driving next to a wall.
The USR semi-slotted rotors are designed to be a little quieter.
Oh ok, 90% of the time i drive with windows up , what i am concerned is regular driving stop and go brake noise, i know my stock ones don't make noise which i like but stop very poorly this i don't like . Questions , Is the ultimax brake rotor the same as the USR or is this a new design/ name that replaces the ultimax rotor? I understand that the USR is the quite performer out of the two, but is the braking distance the same between these two ( USR vs sport) or is the sport dimpled and slotted better performer ?
I'm pretty much trying to decide which is best for me , i like a quite ride but with a rotor that performs the best and im having a feeling that im gonna have make a sacrifice.
Discussion Starter #16
You might be referring to the brake pads them selves making noise. The Greenstuff 6000 & 7000 pads are quiet, the yellowstuff can make some squeaking noise when cold and not under full braking pressure. If bedded and broke in properly, this doesnt normally happen. I run HAWK SD pads which are like the yellowstuff aka metallic and grippy and they do make a slight noise under 5mph under light braking but not at any other time.
USR = Ultimax Sport Rotor. While most use the term interchangeably, there is a non-slotted plain ultimax rotor that EBC makes. The 3GD are the slotted & dimpled rotor. They work great and are both high quality rotors. I find there is slightly more initial bite with USR, as there is more surface area of the rotor to clamp onto without the dimples. Dimples arent needed on a low speed, non-race truck although we highly recommend slotted rotors to help clear debris and keep pad wear even on the rotor face.
1 - 16 of 16 Posts
