1 - 2 of 2 Posts
I put a pair of Energy Suspension greasable sway bar bushings on my 74 Blazer and they were awesome. If anyone knows the measurements I might be the guinnea pig on this one. I am about to install the SAW coil overs so it would be a good time to try them out. Does anyone know the measurements here: Sway Bar Bushings Basically looking for the diameter of the sway bar where it goes through the bushings. Also need to know the distance the centerline of the sway bar sits from the frame. I will be adding the spacer so I will need to add that measurement as well.
I drilled and tapped my brackets and bushings for greasing, myself. Took all of thirty minutes and about a dollar for the zerts (thanks, BobKid for the idea).
I haven't posted any pics or directions for the mod, as it didn't solve my problem (annoying squeaking). My squeaks are coming from the steel sway bar collars contacting the rubber bushing, and not from the sway bar inside the bushing...
1 - 2 of 2 Posts
