1 - 2 of 2 Posts
I just replaced the timing chain in my 2007 FJ. On start, the engine is tossing out a 340 Error Code and all check engine lights come on. If you clear the code it takes two times starting and stopping before the engine will catch. If you drive the car for any given amount of time it starts up fine. Clear the code again and it's hard to start.
Any ideas what might be causing the issue?
Thanks in advance for any help.
Hello @Ohno
Look this link, would appear in priority to a problem with the camshaft sensor, first check the wiring / connection to the sensor.
1 - 2 of 2 Posts
