1 - 2 of 2 Posts
Expo Portal Ham Radio Net - 15 Jan 2008 @ 19:00 PST - Expedition Portal Forums
for those of you who would like to try irlp and join in an offroad net
for info on nodes in your area go to irlp.net and connected nodes list
as for using a node well:
just listen for a bit to make sure it isn't in use (I usually check on irlp.net first also)
then key the mic and say "KE7NKP attempting to connect to the western reflector to join a net" while holding the mic open punch 9251 into the keypad and it is a done deal. You should get an automatic response from the western reflector.
After you are done PLEASE key the mic and say "KE7NKP disconneting from the western reflector and I would like to thank the owners of this repeater for its use" then while holding the mic open punch 73 into the keypad.
That is all there is to it....oh and remember that with the radio to internet to radio delay make sure you key your mic then wait 1 sec to begin speaking or your first bit will be cut off.
Man, I still can't hit the northern repeater from my house w/the handheld. I really need to get a new mobile going....hopefully soon.
Thanks for the heads up Lance!
1 - 2 of 2 Posts
