1 - 20 of 39 Posts
Top fitted and set
remove back two tie downs and use a longer bolt to hold down the back,
the front is held down with 2 turnbuckles attached to the stock front tie
down loops.
Unfinished drawers and top.
Glued down heavy vinyl to top/deck install some flush wood handles
and painted a semi-gloss back.
Well now that's a Daammmnn NICE Job good work!!!:cheers:
very nice, i was thinking of doing something very similar, but i don't konw anything about wood
Not to beat on you specifically, but it is great to hear someone say that. I am not sure I am as talented as Undertow but I could come up with something fairly comparable. Nice to see something I can do after watching all the welding and fabricating going on around here that I don't have the first clue on. The shoe on the other foot is refreshing, hoo-ray for the wood guys!
Great job! I was impressed with your quality. What did you use for the stops or catches on the drawers to keep them from banging in and out? I can see them but can't quite tell what they are.
Discussion Starter #9
Lots of catches/latches out there, found some brass sleves and some 1/4"x 2"
pins that fit into them perfectly. Wanted to keep in simple a clean.
Thanks for the compliments folks.
Very nice! I am too embarrassed to post pics of mine :eek:, although for using what I had and the tools I had it came out pretty nice. But not as nice as yours!
WOW! Very clean looking. Nice to see another wood option.
very charp
Great looking rig, just a couple of quetions: How much were materiels, and how much does it weigh? Thanks!
I have wood every morning! :jawdrop:
Discussion Starter #19
yes it is a cousin to your box Cory, your pic you posted several month ago is what inspired the project, thanks!!
Timbo,
I had the plywood in my shed, but if you were to buy, about
$60.00
Hardware,
$25.00
Vinyl and paint,
$15.00
I would estimate the unit is about 35# empty, I think you could cut about 20% of the weight off if it was built entirely of 1/2' ply.
1 - 20 of 39 Posts
