1 - 5 of 5 Posts
What are the extra wires for with the blue plug that are inserted into the leftmost switch blank?
Left most by steering wheel? Or left most where 8 switches can go? Upper or lower row.
Upper is for Roof Lights or I believe some switch relating to 2wd models. Lower is for Aux lights. Left most steering Fogs
How would you tap into these?
Would you absolutely need a Toyota harness & switch/relay?
Not all spaces are prewired, only a few. If you want to use prewire(such as aux lights), then you would use Toy harness and relay. But if you want to do your own wiring, but use OEM switches, then you'd just buy the connector and pig tails. BTW: The oem aux light harness can be chopped and used however you want and is about 2$ cheaper then the connector and pigs.
Left most where 8 switches go. Top Left.
1 - 5 of 5 Posts
