21 - 40 of 40 Posts
that's the reason I bought an FJ without the roof rack, I didn't necessarily like the looks of it and driving the interstate its noisy and drags the gas mileage down
it's a shame that you can barely find one on the lot without the rack already on it. I immediately replaced my wife's with a low profile Baja rack. It is more attractive, quieter and creates less turbulence. It fits under the garage door easily and is strong enough to carry anything you want. I traveled from Texas to Glacier Nat park and back last summer and slept on it on numerous occasions. The only drawback is cleaning under it.
There are many great alternatives out there. They may not "look or sound as good" on the highway but they are functional. I replaced mine with a Baja Utility Rack and am very pleased.
Forum Gunsmith
Nice pic. Round about...how much was that conversion? How far up does the Baja rack need to put in the supports?
Awhile back ago when I first got mine I got a sunroof instead with the OEM rack and now fear that the OEM rack will be the only rack I can have now.
Thanks! The Baja Utility Rack has minimal clearance above the roof. Bolting down the Autohome Roof Top Tent was a major pain in the knuckles. There is very little room between the rack and the roof in places.In other areas it is fine. This is due to the rack being flat and the curve of the roof. Once you remove the OEM rack, the Baja Rack feet fit perfectly in the same place. Check out their website to see images of the cross members. They would block out some of the sky in a sunroof but for around $750, I have a rack that I can stand on, carry plywood, canoes and roof top tents. For me it was well worth it. By the way, Toshiro Mifune is the man!
Forum Gunsmith
It certainly is more functional than the OEM version. It looks like the sunroof would fit right underneath it as well. I'm going to have to do more research and see if I can sell this OEM as well. It's hard enough to give it away...
My avatar epitomizes me the best from my screen name, what a Ronin or Yojimbo does. Toshiro was the Man. :cheers:
Ditto on that! At firs I was sad my FJ didn't come with one, but now I'm happy cause the Baja Rack and the Auto home Columbus is a marriage made in heaven :) :rocker:
Forum Gunsmith
I tried searching for it again but it was an epic fail. There was either a Gobi or Baja rack extension that worked already with the original OEM rack. It extended the OEM's reach a bit and may be the cheaper alternative both money and time. Does anyone know about it and/or where to find it?
it's junk, i put in a baja rack basket which helps, but in hindsight i would have opted for no rack and gon straight aftermarket.
X2. The basket helps alot though.
I am going to have to Disagree!
I use mine all the time! From luggage, to plywood/lumber to full size box spring and matress!
I dont like the "look" of MOST other roof racks out there!
An air dam on the front capable of supporting some weight would have helped alot, IMO.
Never attempted to use mine, but then, I've only owned the rig for a week.
I wish it was more easily removable and had less worry about losing the parts in the headliner or having leaks. Sure I can seal it up, but should I really have to?
Ronin, the only thing I can think of is the BajaRack basket, which fits into the void in the factory rack. It's on Baja's website under the FJC area. It's about $425 as I recall. I have it and in my opinion makes the factory rack more functional. Easy to install (easier with 2 people, but I did mine alone).
As to Toshiro Mifuni, all I can say is Hai, Toranaga-sama! :ninja:
Forum Gunsmith
Good to know. It's still cheaper than ripping the OEM out and replacing it.
So Wakarimasen, Arigato Oziamashti! :cheers:
Just got this one in the mail - Garvin Adventure Rack XL
^^. Hey, I like that! Is it steel or aluminum? If steel, zinc coated? Thanks.
21 - 40 of 40 Posts
