1 - 14 of 14 Posts
Vendor
Fj Cruiser Gears - 4.56 & 4.88 Ring & Pinion, Lockers, Install Kits Now In Stock!!!
4.56 Package deals: No carrier change required on models with 3.73 now!
Gears for FJ Cruiser, 03+ 4runner, 05+ Tacoma, 05+ Hilux, Prado 120 & GX470
Front 4.56 thick ring & pinion, rear Ring & Pinion, STD installation kits including pinion seals, crush sleeves, nuts, shims, loctite, marking compound, front side/stub axle seals, rear pinion flange/adapter
everything needed to change to 4.56 gears if you have 3.73 now.
$709 w/ std kits
$1099 w/ master kits (models w/o toyota rear locker)
$1129 w/ master kits (models w/ toyota rear elocker)
Front gears alone run $239
If you have 3.90's (fj w/ MT) in your vehicle now you also need:
OEM 3.73 & down STD Carrier $349 or ARB Air Locker RD121 to run these 4.56 gears. Or better yet if you have 3.90 you can run the 4.88 without changing carrier.
Here is a link to them on our website:
http://www.justdifferentials.com/index.php?main_page=product_info&cPath=22_37_484&p roducts_id=2522
Re: Fj Cruiser Gears - 4.56 & 4.88 Ring & Pinion, Lockers, Install Kits Now In Stock!
subscribing
Vendor
Great to hear. These gears took a long time to develop and we did it right. We have sold 100's of sets in both 4.56T & 4.88, with no problems or failures! Thank you for the comments.
I went with their 4.88's and ARB front locker, did Rubicon, Moab, Ouray and drove home to NC w/o problems...
$709 w/ std kits
So, with the auto our only option is 4.56's? What advantage does the masterkit offer?
FINALLY! 4.88 RATIO RING & PINION SET FITS NEW TOYOTA 8" IFS CLAMSHELL STYLE DIFFERENTIAL FOUND IN THE FRONT OF 07+ FJ CRUISER, 03+ 4RUNNER, 05+ TACOMA, 03+ LEXUS GX470, & LC PRADO 120 SERIES. FITS 3.90 & UP CARRIER. MODELS WITH 3.73 WILL REQUIRE NEW CARRIER, OR ARBRD111 AIR LOCKER
So, the auto's can go to a 4.88 ratio if the ARB locker is added?
I'd love to get in a group buy on these. ????????
Vendor
Yes if you have an AT, then you can do 4.56 with out changing carrier. IF you want 4.88 no problem, you just need a new carrier as well. The arb locker replaces the carrier anyways.
I have the 6MT. Tell me everything that I need to buy to switch to 4.88. What will the final drive ratio be?
Thanks.
Vendor
Thanks.
You will need front & rear ring & pinions, install kits (either master or minimum), and a rear pinion flange. Feel free to call and order.
Hello I hv ordered 4.88 ring & pinion and l install arb front lock but need master installation kit if it's sold separately ? Can u give me it's part number to order it ?!
Are you looking for the front or the rear? All our install kits can be found here:
Click on the axle you are looking for: Toyota
Updated links:
All Nitro 4.10 4.56 & 4.88 font gearsets are now "thick" to fit OEM 3.73 carrier or ARB RD121.
I would strongly advise against installing an RD111 now, as you will need to buy a new locker when it comes time to regear. Why not just regear now? 4.56 or 4.88 & 33's or 35's is golden!
07-09 FJ Cruiser:
4.10 Without OEM Locker
4.10 WITH OEM Locker
4.56 Without OEM Locker
4.56 WITH OEM Locker
4.88 Without OEM Locker
4.88 WITH OEM Locker
ARB RD132 Rear Locker 09 & older Rear
ARB RD121 Front Air locker (use with stock AT FJ, or all with Nitro gears)
Chromoly rear axles
We have also seen a lot of failures on 09 & older FJ cruisers and offer this upgraded rearend package click here
2010+ FJ Cruiser:
ARBRD193 Rear Locker 2010+ 8.2 rear
Chromoly rear axles
1 - 14 of 14 Posts
