1 - 13 of 13 Posts
Hello. I am starting my overland build on my 2014 FJ Cruiser and have a couple questions.
I am curious on how I could mount a hi lift jack, 20lb propane tank, 2 jerry cans for water and fuel (or just 2 for water), and a shovel and axe to the spare tire on the back.
I am using a baja rack and Ikamper skycamp 2.0 (or maybe xcamper) on the roof and I think it would be the most aesthetic, convenient, and fuel efficient to have these items mounted on the back around the tire. What are your guys suggestions?
PS: I know its probably not feasible to mount all these things onto the spare tire. If so, what are the other mounting options that are aesthetic, convenient, and fuel efficient?
Thanks!
· Admin
20lb propane tank
I kinda feel like you have a decision to make here, no space-saving grill you'd bring needs this much propane (3-4 of the 1lb tanks are plenty) and the hard-core overlanding guys all end up with trailers with mounted propane anyway.
I have a CampChef Three-Burner but that's not for overlanding, that's for cooking for 40 people on a trail clean-up day.
Yeah I agree. I want the propane setup so I can also run my Mr. Buddy heater in colder situations. Those smaller propane bottles add up overtime also and having the propane bottle on the back saves some space in the car. But thats the option I have to weigh. Buy a propane mount or just go with the little bottles.
· Admin
Thanks for the reply. What rear bumper do you recommend?
There are lots of good swing aways out there, decide what you need and go for the one that closest meets that requirement.
I have a Metal Tech Red Eye swing out and very happy with it.
It weighs 145 lbs dry and you can mount anything on it.
I have also mounted a home made CO2 tank and is holding up pretty good.
My swing out is the older version and since they updated and changed few things.
New version.
Craig from Refined Cycle Off Road makes some amazing products. I have only really needed the 5lb tank for most applications. If you want to carry more than what you see in my setup then I'd highly recommend a dedicated rear swing out bumper like MetalTech or Expedition One.
And because someone will ask.. "no" not all of this weight is directly on the rear door. The gas cans are also supported by a brace tied into the door hinge.
One thing to consider, how much weight do you really want on your back door? That is the nice thing about a swing out bumper, the weight is transferred to the frame(the not nice thing? $$$$$!!). I have heard different numbers on max weight of the rear door, but I personally think I wouldn't go over 200 lbs including spare while driving, at least off road. Parked I wouldn't even worry about weight when the door is latched. Street driving I could go a little higher, 250ish I guess. I have the Garvin trail rack, which mounts to the spare tire mount bolts, and then the spare mount bolts to it, and Garvin says not to exceed 75 pounds on the rack. I didn't weigh the rack, but I would guess its 15-20 pounds or so. A larger spare could run up to 100 lbs or more with rubber and wheel. 5 gallon Jerrys could weigh close to 50 lbs each, full, if you factor the can and carrier brackets. A Hi-lift might hit 30 lbs or more. and then you have 20 lbs of propane, axe? shovel? plus the carrier brackets to hold this stuff.. Its the internet, so I am sure there may be people who disagree with me.. Just something to consider. Don't take my word for it, but just thought I would share my opinion. =)
Bottom line, I think you could find a way to mount all this stuff, but not sure if you would want to.
That's pretty slick!
New version.
This is my favorite of the swingouts as it is supported on both sides. Looks great!
Thanks brother, indeed it is a great swing-out bumper and the new version should be even better what I have.
1 - 13 of 13 Posts
