1 - 9 of 9 Posts
For sale: FJ Cruiser rock sliders/nerf bars/rocker panel protection.
I have a set of All-Pro off road rock sliders for sale. They are new, never used or bolted up. Unpainted. Very well built. Heavy duty. Bolts to existing threaded holes on your FJ. (You will need to get bolts)
Price from All-Pro off road website is $479+shipping for a pair.
I need at least $300.00. You save over $180.
Check them out at All-Pro Off road.
FJ Cruiser Rock Sliders
Info from the web:
Key Features
•Ultimate Rocker Panel Protection!
•High Clearance
•Fully Gusseted
•Completely Bolt-On
•DOM Upgrade Option with Lifetime Warranty
•Made in the USA
Full Product Description
All-Pro Off Road's FJ Cruiser Rock Sliders are the best selling sliders on the market! Get the protection you need for your rocker panels without robbing valuable ground clearance. We designed these Rock Sliders with our signature "kick-out" design that is proven to help prevent damage to the vulnerable rear quarter panel by pushing your FJ away from the rocks. Unlike other sliders, our Rock Sliders angle up to provide the most ground clearance possible since there's nothing worse than getting hung up on low hanging armor!
All-Pro Rock Sliders not only look great, they are designed to stick out just enough to provide the needed protection and to allow for use as a step for roof rack access. No frame drilling is required since our Rock Sliders easily bolt on to the pre-threaded factory frame holes using the supplied grade 10.9 metric hardware. We ship these unpainted so you can finish them to your liking. We recommend using spray paint to allow for easy touch-ups when these sliders get put to good use!
Made in the USA using 1.75" steel tubing for the outer tube with 2" steel tubing for the inner tube, and fully welded and gusseted 2" square tubing for the legs. The beefy frame mounting plates are 3/8" thick plate steel (see photo at left) to withstand bending or tearing away under extreme abuse. Our Rock Sliders will hold the full weight of the vehicle and a Hi-Lift jack can be used at any point along them. They are the most trail-tested product out there and have held up to the country's toughest rock crawling trails including the Hammers, the Rubicon and Moab.
I'm very interested in these but do you have proof that they are the Exteme duty sliders and no the standard ones?
I dont have any proof. The guy I bought them from said they were, I am going off his info. I dont know how to tell any different, they are not stamped with a part number or any other marking. Either way, they are very well built and I doubt they would be easily damaged. Thanks.
Can you ship these? UPS Freight? very interested
1 - 9 of 9 Posts
