1 - 2 of 2 Posts
AMSOIL Online Product Application Guide - 2007%7cTOYOTA%7cFJ+CRUISER%7cZ
*The link is easier to read*
Engine Oil
Grade 1......API*
Signature Series 0W-30 100% Synthetic Motor Oil (SSOQT)
SAE 5W-30 Synthetic Motor Oil (ASLQT)
XL 5W-30 Synthetic Motor Oil (XLFQT)
All TEMPS......5W-30
Manual Transmission,......GL-4
All TEMPS......75W-90
Synthetic Manual Transmission and Transaxle Gear Lube (75W-90) API GL-4 (MTGQT)
Manual Transmission,......GL-5
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
75W-90 Synthetic Long Life Gear Lube (FGRQT)
SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT)
Automatic Transmission,A750F......WS
Low Viscosity Synthetic ATF (ATLQT)
Automatic Transmission,A750E......WS
Standard Differential, Front Part time 4WD......GL-5
ALL TEMPS......75W-90
Standard Differential, Rear......GL-5
Below 0F......80W-90, 80W
SAE 80W-90 Synthetic Gear Lube (AGLQT)
Standard Differential, Front Full time 4WD......GL-5
Above 0F......90
Controlled Slip Differential, Rear......GL-5*
Above 0F......90
Above 0F......90
Transfer Case,Full time 4WD......GL-5
Transfer Case,Part time 4WD......GL-5
Fluids
Power Steering Fluid......AF3
Synthetic Universal Automatic Transmission Fluid (ATFQT)
Torque-Drive Synthetic Transmission Fluid (ATD1G)
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN)
Clutch Fluid......HB
FILTERS:
Oil Filter MANN 7500-Mile Oil Filter (ML1003) [1]
Air Filter Absolute Efficiency Air Filter (EAA238)
Air Filter WIX 46888 Air Filter
Cabin Air Filter WIX 24875 Cabin Air Filter
[1] Guaranteed up to 7500 miles when using AMSOIL motor oil.
NGK PLUGS AND WIRESETS:
IXIRIDIUM PLUG LFR6AIX-11 NGK6619
PREMIUMPLATINUM PLUG PLFR6A-11 * NGK7654
PRERIUMIRIDIUM PLUG ILFR6T11 ^
VPOWER PLUG LFR6C-11 NGK7787
VPOWER PLUG LFR6C-11 # NGK7787
WIRESET WIRESET Direct Fire Ignition [1]
[1] No Wires Req'd
WIPER BLADES:
Blade Class Driver Passenger Center
ExactFit T141
ExactFit T161 T141
ExactFit T141 T141
NeoForm T16160
NeoForm T16140 T16140
Winter T37131
Winter T37160 T37131
Winter T37131 T37131
CHASSIS LUBRICATION:
5 Fittings, 0 Plugs
CAPACITIES:
Engine, with filter..........5.5 quarts [1]
Cooling System, With AT Initial Fill..........10.4 quarts
AMSOIL Antifreeze and Engine Coolant
Cooling System, With MT Initial Fill..........10 quarts
Automatic Transmission, A750E Initial Fill..........3.2 quarts
Automatic Transmission, A750F Initial Fill..........3.2 quarts
Automatic Transmission, Total Fill
5 speed A750F..........5.8 quarts
5 speed A750E..........5.8 quarts
Manual Transmission, ..........3.9 pints
Differential, Full time 4WD Front..........3 pints
Differential, Part time 4WD Front..........3.2 pints
Differential, With LSD Rear..........6.2 pints
Differential, Without LSD Rear..........6.4 pints
Transfer Case, Full time 4WD..........3 pints
Transfer Case, Part time 4WD..........2.2 pints
[1] After refill check oil level.
TORQUES:
Oil Drain Plug.....30 ft/lbs
Manual Transmission
Fill Plug 27 ft/lbs
Drain Plug 27 ft/lbs
Transfer Case
Fill Plug 27 ft/lbs
OTHER TOP QUALITY PRODUCTS:
Mothers® Car Care Appearance Products
By-Pass Oil Filters
PI Performance Improver Gasoline Additive
Product Recommendations and Drain Interval Chart
1 - 2 of 2 Posts
