1 - 5 of 5 Posts
Hi -
Has anyone installed XM with their FJammer radio? If yes, did you need to buy the XM receiver, which essentially comes with a need to install the magnetic receiver on your roof, and extensive wiring that uses the Aux as well as (sigaret lighter) power plug OR were you able to merely activate XM by opening an XM account, and having the activation signal being sent to your radio ID, as the FJ manual suggests?
Any advice would be much appreciated,
Cheers,
Johannes
you need the reciever and the fit kit. The dealer put it in for as part of the ***ked up deal I got on my FJ. It worked great though.
fka trailman
just get a plug an play with an antena boosterthats what i did
fka trailman
its a street sign i took from work. i cut it out and bent it to fit the bend in the headliner and mounted it to the rearview mirror
1 - 5 of 5 Posts
