1 - 20 of 27 Posts
Here is my Pre runner with a few added items over the last year.
The day I brought her home.
First thing to change on day 2
Added a Scan Gauge
Added the aFe CAI from the group buy
Added a R.E.D light bar and PIAA 520's
Added the Dirty Parts Dual Battery
Added the 2" Lift with FOX adjustable Suspension Front and Rear
Added the All Pro Rear Springs and Upper and lower links
Added Air Dam/Light Bar and PIAA 510's
Added Lucrum Winch Mount and MM PE8000 Winch and PIAA 510 Fogs
Added CB, Bandi Mount and Hi Lift Jack
Added Custom Axe and Shovel Mount
Added Trail Gear Sliders
Added Spidertrax Spacers for stability
Added Roof Top Carrier
Added Color LED Switches for all the aux lights
Added Tuffy Cargo Box
Moved the GPS above the Mirror
More to come....
GJ Tim! I like the clean install. You've gotta come and play with us sometimes. :)
You forgot to mention your dual horns.
Yep...Thats them 2 red things in the grill...Gunna be black soon.
I will play eventually, I want to have most everything ready so I am prepared for almost anything that can happen on the trails. I like the proactive approach to things.
The beauty of traveling in groups is you have security in wheeling. There are people to help and you are less likely to get into trouble then when you wheel alone.
Nice build!
I agree.....nice work! What size wheels and tires are you running?
Thanks Penrose. The Tires are 265/70/17 BFG AT's on MB Razor wheels 17x8.5/4.5" backspacing/-6mm offset with spidertrax 1.25" spacers.
Can you tell me which air dam that is?? The holes seem to be huge.
It's an All Pro...The holes are around 5.5 to 5.75 inches in diameter. 4" lights fit great but anything bigger sticks out and over the top.
Looks great Tim.
:bigthumb:
· Kokopelli Moderator
Nice one, Tim! Have you thought about switching to the 4WD springs? Other threads show it pops your front end up a little bit--little more clearance!
Discussion Starter · #12 ·
Thanks....I've got the Fox 2" Adjustables on there so I could adjust it up higher but I have it sitting level now.
MAN, that thing is looking good, like a prerunner should!:)
Discussion Starter · #14 ·
Just deciding on what skids to get now.
Discussion Starter · #16 ·
Added the Demello Front Skid
Discussion Starter · #18 ·
Larry, Thanks...I have not forgot about taking you up on that offer.
Discussion Starter · #20 ·
Do you happen to have a thread on how you wired your roof lights?
Thanks.
Did not do a detailed thread. Its rather easy if you know 12V electrical, but time consuming to do it right.
1 - 20 of 27 Posts
