Do you have a good ground? I would check that first.Anybody know any reason why, if everything else works, i.e. fog lights turn on/off, dimmer illumination works, the LED within the factory AUX switch doesn't?
Was it working before? Was this from the factory or your own install?Anybody know any reason why, if everything else works, i.e. fog lights turn on/off, dimmer illumination works, the LED within the factory AUX switch doesn't?
I will check the ground, that's a good suggestion.Do you have a good ground? I would check that first.
This is a new switch I put in recently, its the toyota aux switch.Was it working before? Was this from the factory or your own install?
If it hasn't worked period, then you mad some error wiring it. Did you tap the "power" for the LED to the "power out" wire on the switch?I will check the ground, that's a good suggestion.
If you used the OEM harness and followed the OEM instructions, then you did everything correctly.Hey guys, here's a good one for you...
I installed new foglights yesterday, abiding by the factory installation instructions and using the OEM switch. I got it wired up, T-tapped into the A-trac illumination wires and plugged the white plug into the corresponding location behind the driver side kick-plate and properly grounded it. I then cut the plug off for the foglights in the engine bay and wired my foglights in accordingly and installed the relay and 15A fuse in the fuse box. I went to test them and the only work with the high beams?! Is something crossed? I cant imagine this is how they are supposed to function. My 4Runner worked just the opposite way, i.e. low beam w/ fogs.
Can someone help me?
If you used the factory harness/instructions then yes...they are functioning correctly...ie only with the high beams on.Hey guys, here's a good one for you...
[/I]![]()
When I followed this thread as well as the Toyota factory bit to install mines I fused into the slot next to the red 10a fuse there in the pic. Mine runs with high, low, and even when the running lights are off. They also shut off when the truck is off or if I leave my lights on when I get out the auto shut off feature kicks in.This thread is confusing to say the least. At the end of the day, if you follow Toyotas instruction manual for a "clean" install. You can only use the new fog lights with high beams.
This sucks donkey dic*.
I applaud your efforts in helping others. We really appreciate it.:clap:No problem. Glad you got it installed and working!
That's the great thing about this site...lots of helpful folks! I'm happy to contribute when I can.
If you use the factory wiring harness you can just plug and play. Fuse and relay plug into the fuse block under the hood. The under dash harness plugs into the switch and wiring harness.Whoa that take apart looks intense. But maybe just cause its on paper. Ive taken apart the dash and console of my honda before and it was so easy after the first time. Thanks so much for your help. This is gonna be fun.
