Hopefully this is not something very many people will ever need to do, but since I had to replace mine I thought I might as well document the process just in case anyone else ever does need it. Even if you are not replacing your ADD actuator, perhaps the photos will take some of the mystery out of it for you and you will understand how your truck works a little better.
First off, an explanation of how the front differential on our IFS trucks work:
The front diff does not have a traditional "pumpkin" like the rear diff and trucks with solid front axles. Instead, the front diff on the FJC is a clamshell type, meaning that the carrier housing opens side-to-side instead of from the front like a traditional pumpkin. This saves space and weight, at the cost of being a little less sturdy than a traditional pumpkin. The extra space is important because the extra CV joints and half-shafts necessary for IFS take up more real estate than a conventional front axle. Fortunately, because of the CV joints and half shafts will allow higher angles, the front diff is up pretty high and fairly-well protected by frame cross-members and suspension parts.
Manual transmission FJC's have full-time 4WD, and both front half-shafts always turn under power, but auto-tranny FJC's have a part-time 4WD system in that the front driveshaft does not turn until the transfer case is shifted into 4-High or 4-Low. To save some wear and tear, the passenger-side half shaft is disonnected via a sliding sleeve slip yoke when 4WD is not engaged. They could have done the same thing by using locking hubs at the ends of the front axles (like 60-series and older Land Cruisers and heeps, Broncos, Scouts, etc.) but I guess they figured AT5 FJC owners would be too lazy to get out of the cab and turn locking hubs on and off, so they invented this sliding sleeve system and and called it "ADD" for Automatic Disconnecting Differential. Because the driver's side half shaft is always connected to the differential, the rolling left front wheel turns the differential gears at all times, but because of the magic of the differential the drive shaft does not turn and thanks to ADD the passenger-side half-shaft does not turn either, until 4WD is engaged.
Here is what the ADD actually does: when 4WD is engaged, a switch in the transfer case activates a small electric motor in a housing on the front of the differential housing. This little motor turns a worm-drive gear, which turns a larger conventional gear, which slides a large metal fork inside the differential housing that is connected to a ring slot in the sliding sleeve, moving the sliding sleeve about 1-1/2" so that the interior splines in the sliding sleeve connect with the mating splines on the differential clutch hub, and now both both front half-shafts are connected to the differential. At the same time, the transfer case now provides power to the front drive shaft, turning the diff from the pinion side, and forcing power into whichever side of the diff has the least resistance. If the ADD did not provide a connection to the passenger side, then the diff would not turn the driver's side wheel either as the non-connected side of the diff would be the path of least resistance. When the transfer case is shifted back into 2-High, the motor in the diff actuator runs the other direction, and the fork slides the slip yoke sleeve back the other way, disconnecting the passenger-side half shaft from the diff.
So, the workings of the ADD are automatic and require no thought or effort on your part - until it quits working and you don't have 4WD. This happened to me on a fairly difficult trail, and would have made the obstacle I was on impassable but for the fact that I have an ARB locking front differential, and was thus able to lock up the diff and force power into the driver's side front wheel, giving me at least 3WD.
If your front diff is not engaging 4WD (the little 4WD light in the dash blinks eternally or will not come on, confirm by jacking up the front end and trying to turn either wheel with the transfer case in 4WD - if the ADD is engaged, the opposite wheel will turn the opposite direction, if not then either wheel will spin independently of the other), you can test the actuator still on the truck with a multimeter / ohmmeter and some test leads with female spade lugs on them, per the factory service manual. If your actuator fails these tests like mine did, the actuator will need to come off for repair or replacement.
On to the R&R:
This job is easier with the truck securely up on jack stands, but possible to do without.
Remove whatever front skid plates are present, including the factory sheet metal covers if you still have them.
Drain the front diff; the plug is on the driver's side bottom of the diff and requires a 10mm hex bit or allen wrench:
Here is a photo of the actuator in place, on the front side of the diff. The photo is necessarily taken from a low angle, underneath the diff and from the side:
Disconnect the actuator vent breather tube from the nipple on the diff side of the actuator.
Disconnect the electrical connector on the opposite side of the actuator (shown in photo, above) by pinching low on the connector on both sides.
Support the diff with a jack, remove the two mounting bolts that go through the "hockey pucks" on the front-most frame cross member with a 22mm socket, and the mounting nut in the frame cross member behind the diff with a 14mm hex bit.
Lower the jack supporting the diff; it will droop several inches and hang on the half shafts / CV joints, allowing easier access to the actuator. Although the Factory Service Manual does not say to, I found it easier to also remove the passenger-side mounting arm from the diff housing with a 19mm socket.
Remove the four bolts attaching the actuator to the diff housing with a 12mm socket. The top passenger-side one is harder to get to and may require a universal joint and extension. Remove the actuator by tapping gently with a rubber mallet; it is glued on pretty good with nice red Toyota FIPG sealant.
Here is a side view of the removed actuator, showing the shifting fork:
Here is a photo of the diff housing with the actuator removed, showing the sliding sleeve and the groove in it the shift fork fits into. The sleeve is in the disconnected, 2WD position, and you can just barely see some of the splines on the differential clutch hub in the far right of the opening:
Likewise, here is the sliding sleeve in the connected, 4WD position:
Although the FSM says to replace the actuator, the actuator actually does come apart by removing the five Phillps-head screws on the black plastic cover. Removing the cover, you will see this:
the gears that actually move the slider shift fork, and the electrical contacts on top of the big gear that turn the motor off when the gear (and shift fork) has moved far enough.
Inside the black plastic cover looks like this:
here you can see the electric motor and worm-drive gear, and the mating electrical contacts for the ones on the big round gear in the previous picture. The gears and contacts were well greased at the factory, but after three years and 90,000 miles worth of heat from the engine and front diff, the grease in mine was starting to dry out and was no longer soft. A common problem in older Land Cruisers is parts sealed at the factory with "lifetime" grease that dries out and petrifies over time, and this actuator definitely has the possibility to be headed that way.
A close up of the motor shows why I believe this actuator failed:
One of the two power terminals on either side of the motor was not touching the contact in the black plastic cover. The contacts appear to be only a press fit! I actually took this photo after I soldered both contacts and their motor poles together. This appears to have fixed the actuator, but since I had already purchased a new one, I installed the new one and will keep the old one for a spare. If you need a new one, the part number is 41400-35031 for the actuator assembly. Be warned that the list price is $364, though you can get it for a large discount from a number of dealers that give a discount for TLCA members like Sierra Toyota in Arizona (where I got mine) or American Toyota in Albuquerque, NM.
A side note, if you were ever stuck on the trail with the actuator broken like I was - now I know that it would be a relatively simple trail fix to remove the failed actuator, slide the sleeve by hand to engage both half shafts, turn the gear inside the failed actuator so that the shift fork is in the engaged position, reinstall the failed actuator, and don't plug it in! Now your front axles will both be engaged for the rest of the trip, and you can shift the transfer case to 2WD whenever desired and stop the front drive shaft from turning. The wheels will still turn both front half shafts and all CV joints, but that won't hurt anything. To affect this trail fix, you will need to carry good quality FIPG silicone compound and some gear oil (or a clean recepticle to drain your gear oil into) with you.
To install the actuator is pretty much the reverse of thye removal. Fastidiously clean all traces of the old FIPG silicone from the diff housing (and the actuator if you're reinstalling the same one) with a gasket scraper or razor blade, clean both pieces with brake cleaner or other non-residue solvent, and run a bead of high quality, high-temp Silicone FIPG around the opening in the diff housing. The manual calls for Toyota FIPG, or Three Bond #1281. I happen to have a tube of the Toyota and it is very high quality but also very spendy.
Don't get too happy with the FIPG because you don't want an excessive amount to squeeze into the actuator cavity and interfere with the turning of the gears or the gear oil necessary to lube the shaft of the sifting fork.
Tighten the four bolts that attach the actuator to 15 ft.lbs.
Reinstall the differential support arm (if you took it off) but don't tighten the bolts all the way yet. Reinstall the long bolts that hold the support arms to the frame cross member, and torque to 101 ft.lbs. Reinstall the differential mount nut aft of the diff and torque to 64 ft.lbs. I used Blue Loctite on all of these, which is not called for in the manual but I HATE having stuff like that fall off so I use Loctite to make sure and sleep better at night. Finally, torque the diff support bolts to 118 ft.lbs.
Reconnect the electrical connector and the vent hose back on to the diff actuator. Put the drain plug back in the diff with a new metal gasket and a dab of anti-seize on the threads, and torque to 48 ft.lbs. Wait a few hours for the FIPG cement to cure (if you're not stuck on the trail), and re-fill the diff with good synthetic gear lube; I use Amsoil Severe Gear 75w-90. The fill plug is halfway up the diff clamshell on the driver's side:
Fill it until gear oil trickles out of the fill hole. Stop part way through filling, turn the driver's side wheel to turn the diff gears and force gear oil into them, let it settle for a minute and then fill the rest of the way. A hand pump makes this job a breeze. Install the fill plug with a new gasket, a dab of anti-seize on the threads, and torque to 29 ft.lbs. Put your skid plates back on and you are done! :king:
Sweet write up! I don't look forward to the day, but now I can at least proceed with a little confidence.
I have a friend with an 06 Taco who recently had major issue with his ADD and T-Case electricals. He replaced just about everything (switches, ECU, ADD switch) and it still wouldn't engage 4WD. His t-case was electronically activated, not manual like the FJ. Finally ran out of bank and patience and added a manual lever to the outside of his t-case and installed his own ADD switch in the cabin. A little inconvenient, but took some of the guesswork out of the equation. If he really wanted to finish it off, he could fabricate linkage to a shift lever in the cabin for his tcase too.
Thanks for the write up. You saved me a few hundred dollars not having to replace the ADD. I found that the repair could be made without removing the unit from differential. In under an hour a problem that's been giving me fits for months has been repaired. Thanks again for your look inside of the actuator.
This thread was instrumental in helping me fix my non operating 2002 Toyota Sequoia 4wd system - which was fixed when I replaced the front ADD actuator assembly. My ADD actuator is a little different - but very similar - so your step by steps and photos were very helpful. I could get my old one to 'cycle' but not reliably - I just think it was too old and the 'tracks' had worn? Anyway, new one put in and 4wd fully operational in this weekend's 6" snow. Thanks so much for this excellent thread.
Just found this and learned a whole lot about the ADD I didn't know. Many thanks 1911.
Do you suppose one of the reasons Toyota recommends putting the transfer case into 4H at least once a month is to exercise the ADD and the sliding sleeve? In other words, could the lack of actuation of the ADD system cause it to potentially hesitate or stick?
Is the majority of ADD problems electrical or is mechanical problems quite common as well? Thanks for any info.
The sliding sleeve itself is well-lubricated along with the axle half-shafts by the gear oil in the diff and axle(s) cavity, and is unlikely to stick IMO. What is much more likely is that: a) the grease on the little plastic gears in the motor housing gets hard and stiff, probably more so if the electric motor and plastic gears are not exercised, and b) the electric motor power connections are weak points, susceptible to corrosion and/or lack of physical contact. This cannot be helped by exercise of the unit.
All the ones I have seen or diagnosed turned out to be electrical, not the mechanical fork or sliding sleeve.
As a follow-up to the documented replacement on my own truck, the brand-new actuator I installed in the article above also failed. This time, the vent nipple on the top somehow got broken off (I suspect a defective part in the first place but cannot confirm) and water from several deep-water crossings in the course of a week-long northern Colorado back-country trip got into the electric motor housing, and eventually rusted up the motor and most of the metal inside the plastic housing. I re-installed the original actuator motor and assembly that I had repaired by soldering the motor power connections, making sure that the plastic housing including the vent nipple was intact and connected to the vent line. The repaired original continues to work perfectly, knock on wood!
Too bad the motor isn't a more sealed unit with better connections. Perhaps, an aftermarket motor from the model hobby industry is a solution. There should also be an access cover with an o-ring seal to enable easy inspection and cleaning/lubing. Hmm, Idears, Idears.
Judging by your statement below can I test too see if the ADD is bad by doing one of the two test or must I do both to confirm? The 4wd is out and im now 2,000 miles past warranty so im trying to figure out what is going on and how to correct the problem before the snow hits.
"If your front diff is not engaging 4WD (the little 4WD light in the dash blinks eternally or will not come on, confirm by jacking up the front end and trying to turn either wheel with the transfer case in 4WD - if the ADD is engaged, the opposite wheel will turn the opposite direction, if not then either wheel will spin independently of the other), you can test the actuator still on the truck with a multimeter / ohmmeter and some test leads with female spade lugs on them, per the factory service manual. If your actuator fails these tests like mine did, the actuator will need to come off for repair or replacement".
@MCHA - I don't know the answer - hopefully others can weigh in.
I'm working on my ADD currently.
When I disconnect the connector - I'm getting a positive reading on the ohm meter (bottom two pins on ADD). Therefore I believe the ADD is working properly.
However, when I put a volt meter on the corresponding pins I get 0V (even when the transfer case is engaged into 4WD). These are the Black Wire + Red Wire.
When I keep the volt meter on the Black wire - and roll through the other pins - I get about 10V on every other pin.
Checked the 20V Fuse near the steering wheel, it's all good.
Seems the Red & Black wires on the connectors would be providing 12V when engaged into 4WD.
I feel my issue is not necessarily the ADD - but getting power to the ADD.
Any thoughts??
Can anyone test their connector and verify if the bottom two pins should be reading something vs 0V. Thanks!
Thanks for the write up, didn't even know this existed.
My 4w lights would not come on, the transfer case was working. I check the front tires, they spun independently.
I cleaned the electrical connectors with cleaner at the add, knocked alot of mud out pulling the harness off and gave it some luv from my hammer and prayed, it worked. 4w is back. I was going to check the electrical as you did, but remove the cover in place, but my screws are toast on the cover. I got lucky I did not have to pull it all together.
Throwout Bearing Trouble on 6 speeds (lots of tech and pics contained within)
UPDATE : PDM now produces a kit for our trucks, thanks to everyone's participation in this thread. I thought I'd update this OP to say this thread has turned into a pretty decent tech & pictures piece. If you have...
I was inspired by san antonio FJ to do this mod from his post at http://www.fjcruiserforums.com/forums/showthread.php?t=7462.
So I started by unplugging the VSC and stripping the e-tape and cover to expose the wires.
Then I found access into the cabin through a removable grommit (careful I...
I have 2008 fj cruiser 4x4 with a Left Rear Axle Seep, enough that it is now on my left rear brake pads But, is not getting onto the inside of that rear tire as of yet.
"I want to replace this axle seal myself".
*I am asking for suggestions on the Best Brand Axle Seal I should buy & which Brand...
So I installed a VSC off switch in my 08 last week by following “Ruebarb’s” instructions & connecting the blue wire w/ yellow stripe to 12v power.
Everything works, and I can turn the vsc back on....until it doesn’t for some reason. As seen in one of the pictures, the “vsc trac” light comes on...
Has anyone done this? I found one thread where someone said they did but didn't really give any info.
Would it be as simple as getting a lockable centre torsen from a 4runner and swapping it in?
We have old windy roads here that were once tarmac and are now a combination of old tar and gravel...
