1 - 11 of 11 Posts
SOLD!
NOTE: I WILL NOT SELL ANY OF THE COMPONENTS INDIVIDUALLY.
I am selling a full SAW kit for the FJ Cruiser. The kit only has 6,000 miles on it, none of which is from off-road use (I have yet to get off-road thanks to my job). After I removed the kit from the FJ, I sent it back to SAW and had the chrome housings replaced with their new rust-treated stainless steel. So rust shouldn't be an issue.
The cost new was right at $1,600. Asking $975 plus actual shipping costs by Fedex Ground - NON-NEGOTIABLE ON PRICE. All parts are included, including the original paperwork from purchase. The SAW description is below. For extra photos, you can go to E-Bay auction #280237960540
FJ Cruiser SAW Lift Kit Description:
Sway-A-Way offers their 2.5" (refers to piston diameter – NOT HEIGHT) adjustable racing style front coilover shocks for the FJ Cruiser. These shocks can be adjusted from 0"-3" of lift. Each shock set includes a spanner wrench for adjustment. They are rebuildable and revalveable. They have a 200psi nitrogen charge. They have full spherical bearing type upper and lower mounts. These US made shocks feature top notch machining and design, 7/8" NitroSteel shafts and red anodizing. They bolt on your truck with no modifications and WORK WELL WITH YOUR FACTORY CONTROL ARMS. Sway-A-Way is the industry leader in racing shock technology.
Rear Coil Set: Provides approx 1.5" of lift and a 12% increase in spring rate. Color is RED.
Extended Travel Rear Shock Set: These are rear 2" racing shocks tuned for SAW's heavier rate rear FJ springs and made to match SAW's front FJ coilovers; rebuildable, revalveable, nitrogen charged, lower bearing mount, massive 7/8" shaft.. Provides an extra inch of droop. Way Cool!
Man, that is a great freaking deal
It's a nice setup. I switched to Walker Evans adjustable reservoir, which is more plush. But honestly, I liked the performance of the SAW setup better.
P.M. Sent
Responded to your PM Phoenicks.
Not sold? Well maybe I can work up the cash....... Shipped to 87010?
Thanks......
Discussion Starter · #11 · (Edited)
Thanks......
I have no idea, and won't know the shipping cost until I go to Fedex (Ground). There will be three boxes - 1) coilovers; 2) rear shocks; and 3) springs and parts. My plan is to charge $65 for shipping. If the shipping is substantially less than that, I will refund the difference. I suspect it might run a bit more, in which case I will have to cover it. The parts are not light.
1 - 11 of 11 Posts
