I had a few hours this afternoon and started on installing my FTM-350. I got a lot of it done but then got stuck. The antennae (Diamond NR-770) is going to be mounted to my BajaRack in the driver's side front corner.
How do I get the cable from there into the cabin? Is it possible without drilling a hole?
The main radio unit is going to be mounted from the underside of the driver's seat. I got the wires run, just need to make a Home Depot run for some larger washers and maybe some kind of bracket. I plan on using the existing mount that came with the radio so if you have ideas, I'd love to hear them.
I took 1911's idea and epoxied a piece of 2x4 to the roof. I need to go pick up a mount for the faceplate but I put all the cables up there already.
When I get the mount, it should look something like this.
For the GPS receiver, I'm thinking about using some double sided tape and putting on the dash pod. What's the best way to get the dash off to route the wire?
