So before I begin this process of replacing my fuel pump, I think I should make a post to see if I am missing anything super important before I begin. My experience level is intermediate at best. I took a few years of auto shop in H.S. and learned a lot about working on cars in that class. We worked mainly on older hot rods and VW's that were in the shop so my knowledge never really translated to newer cars. I have done a lot of wiring work and replaced the sound systems on several vehicles. I have replaced alternators and belts on my previous F-150's. But this is my first Toyota vehicle and I am not extremely confident. I have a manual transmission 2007 FJ with just under 130K miles on it.
Problem: While approaching a stop sign (in neutral) my engine died and the check engine light came on. I tried starting and the engine just kept turning over but would not start. So I figure either no gas or no spark. I had a friend come over with a code reader but the engine would not give an error code even though the check engine light was on. Maybe this was because it would not start. So we decided to pull the fuel line just in front of the fuel filter that is under the hood. When we pulled this line and tried to start the engine no gas was coming out. We then used starter spray directly into the intake to see if the engine would start, and it did. Because it started with starter spray and there is no fuel coming out of the fuel line I am assuming it is a bad fuel pump. Please correct me if I am wrong on this or if there is anything else I should check before pulling the fuel pump.
My Solution: I am going to try and use the hack seen on YouTube (found in this forum) where people cut the floor panel to increase the size of the access hole under the rear seat. It looks fairly simple and I do not really feel like I have the ability to drop the tank on my own without running into major hangups and headaches.
My Questions: Which fuel pump should I buy? Looking online I see two basic variants, one with the plastic housing included and one that appears to be just the pump that I would install into the housing. The difference in price is about $120-$150 so I am not sure what option to get. If it fairly simple to replace the pump inside the original housing then that's what I would prefer, but I don't want to do that if there are complicated procedures or if I will need ti zip tie anything in place. I'm assuming one just has to be installed inside the original housing and the other just replaces everything. Has anyone replaced their fuel filter have any advice about which type of pump or which brand to get that will work best. I am not really interested in getting something top of the line, just a simple replacement that will work as well as the original. Any advice would be helpful. The options I am seeing from Auto Zone are either Delphi or Spectra and range in price from wothout the housing the two options are $360 and $790 respectively, while the two with housing included are $480 or $535.
