1 - 7 of 7 Posts
Re: fuse box map
I saw one once, I think it was on a thread by either Shadow Warior or Land Cruiser Steve..
Re: fuse box map
I think Swiss Army SUV had a picture with the fuses marked.
In the (Very useful) map above he is tapping into the fuse panel and I am assuming using an external fuse block. Is there anything to prevent you from tapping into the back of the panel and using a blade fuse right in the factory block? I am looking to add a couple 12v outlets (Always hot) in the rear next to the 110v receptacle. I have done similar projects using inline fuses but it would be much nicer to have all my fuses on the factory panel for ease of access.
if you dont have the sub woofer,you can splice into the wire for it (it's prewired for the sub). I would have to look and see whice wire it is but it is on its own 20a. I have two tapped in and have never had a problem in 5 yrs.
1 - 7 of 7 Posts
