21 - 40 of 58 Posts
I did it in my car> if you want to do all things Oem,, it will cost you a lot fro nothings.
I recommended you to only buy just the foglights+Pads with the switch only.
and make your own wirring. puls you can control the foglights as you like, instead of the stupid oem control (only work with the Low beam)
i can get wiring here
Do yoi know price of lights and wings there?
# I really don’t remember how much exactly. But it’s around $300 I guess.
Of course, painted Silver like the old one. For the lights and wings.
About the lights, it is Toyota universal.. you can find it in many Toyota and Lexus cars.
Not that good, for me..
I recommend you bought an Led version.
Toyota Led fog light like what in Lexus.
Or better - Best option: from:
https://www.theretrofitsource.com/
Discussion Starter #23
for me the fog lights itself arent imp
I would like the black wings with the holes. My TT is all black and I dont want to paint the silvers
I got a set of Jogon single LED bumper wings and they are already black and come with everything for under $200. I have yet to install. They look as solid as the current wings and I can always replace the lights with a better insert. Here is the Aliexpress listing:
JOGON 2pcs/set Light Kit For Toyota FJ Cruiser 2007-2017 BLACK Fog Lamp DRL Daytime Running Light Driving Light Kit
I got a set of Jagonese single LED bumper wings and they are already black and come with everything for under $300. I have yet to install. I will post some pics soon.
link where you got them? Quality?
As I mentioned, I have yet to install, but initial impressions are good. Reviews are good for the Jogon brand.
US $150.23 12%OFF | 2pcs/set Light Kit For Toyota FJ Cruiser 2007-2017 BLACK Fog Lamp DRL Daytime Running Light Driving Light Kit
https://s.click.aliexpress.com/e/ckLxCYmk
Discussion Starter #27
How does the quality feel to You? Are you using oem harness and switch or using their provided wiring?
Not sure yet what harness I will use. I currently have a set of PIAA foglights mounted on a bullbar, but I am planning to install my new Metal Tech hidden winch bumper with these new wings attached. I will consider using the PIAA harness if possible since it is already wired to a switch, but the JOGON harness seems adequate otherwise. The wings themselves feel at least as high quality as OEM.
Discussion Starter #31
Great to hear its good quality!!
2007 FJC 4x4.
Sounds worth it for OEM
Discussion Starter #37
The Ebay OEM aux wiring harness + switch that USDM dealers sell for $112, that should work for these WING FOGS I ordered, right?
https://www.ebay.com/itm/273798932920
or are there differences between doing fogs and aux lights ?
Appreciate the help
Most all Toyota fog lights are the same, so I am almost certain they are direct fit to the OEM bumper wings that look like these.
On my China-knockoffs they almost fit...had to slightly adjust, but the overall answer is yes...so now I have OEM fog lights that work like OEM fog lights, which is nice.
See how the crappy China ones started melting? You can also see how the mounting holes are a touch off. I had to trim those on the Taco fogs to fit my Chinese wings.
wee bit of trimming
if you get OEM wings, I am betting they would come with OEM fogs and thus be perfect. However, if you cannot source OEM, you can get a pair of Tacoma fogs for $40-50 as takeoffs.
The problem is it is not worth doing what I did. $200+ on the Chinese kit, then having to repaint them and spend money on Tacoma fog lights. Im probably $300 into this lol
This is the OEM kit sans wiring: https://www.ebay.com/p/Genuine-Toyo...H-RH-Pair/23006770257?iid=113695490793&chn=ps
2007 FJC 4x4.
That should work. Technically no difference. If you hook them up using factory wiring they will turn off with your brights on, but not a huge deal. Connector at the bulb could be different I suppose, but that is an easy splice.
Discussion Starter #39
Excellent - thank you.
Discussion Starter #40
are the oem fogs i got H11?
How many watts?
I want some better bulbs when i install them - but dont want to fry wiring etc
Thanks!
Also can you get lamin x type clear covers for the fogs and headlights?
21 - 40 of 58 Posts
