1 - 20 of 119 Posts
As many members have reported, there have been a lot of issues with previous generations of Lifetime LED headlight bulbs. I was one . . . I had issues with 1.0 and 1.5 :mecry:. Luckily Lifetime LED moved from NY to UT and I got my third set today and installed them.
Here's wishing for the best!
Now for the install!
Here is a shot of the light itself:
Light comes apart in 2 pieces:
This is how I installed it . . . start with the clip in piece first:
And install it:
Then make sure the reflector is up like the factory bulb:
Stick it through the grommet:
And install it by pressing it into the clip:
Now for the supply thingy:
Just simply connect it to the LED bulb:
Now plug into factory connector and let there be light!
Follow up by using a few zip ties and drink a beer! :cheers:
I Have a V-8!! Moderator
You must need one hell of a long extension cord to plug that power supply into...................or a generator in the back....
Looking good.
Where did you purchase your LED's from, cant seem to find a model that is specifically "Gen 2.0" on the lifetimeLED website.
Its their typical H4 bulb. They will only sell the newest version from here on out.
https://www.lifetimeledlights.com/led_lights/h4_9003_70w_headlight
Try @PureFJCruiser or @Red Dirt Offroad and support a vendor.
The pictures are not updated yet. Pure shows Gen 1.5 and Red Dirt shows Gen 1. I remember Red Dirt mentioning only the newest generation will be shipped when ordered.
http://www.purefjcruiser.com/led-lighting-c-15/h49003-70w-led-headlights-for-fj-cruiser-20072014-p-6080.html
https://www.reddirtoffroad.com/lifetime-led-lights-h4-9003-70w-headlight
$126 on sale at Red Dirt :) I might have to pull the trigger.... I hope that's gen 2 on sale?
Pulled the trigger @ Red Dirt Offroad :) $27 for ground shipping stings ... but no tax :)
Thanks for the write up with pictures @Ferby I needed that bit of confidence that the swap was easy and the results would be good.
Discussion Starter #14
Regardless of cost, I prefer the whiter color of the 5000k bulb ($127) over the blueish 6500k ($211). Hopefully the bulbs I bought are brighter than OEM. Plus, I have DRL and the 70w model doesn't recommend DRL.
My gen 1 & 1.5 weren't bluish, so I hope these aren't either.
Discussion Starter #19
Let us know how those are over the 6500k. Post up some pics too.
And install it:
Good write-up, but I want to add one thing: instead of sliding the dust boot onto the bulb and then installing the bulb, it is easier to install the boot right after installing the base & then the bulb slides right in.
The light pattern is definitely different than either of the others that I had. I still need some more drive time on them and I need to tweak the alignment.
One main difference is on the old bulbs when you put the high beam on, it was in addition to the low beam. The gen 2 turn off the low beam when the high beam is on just like on stock bulbs.
1 - 20 of 119 Posts
