Thanks brother!Haven’t been around much but your build never disappoints! Glad to see you are still at it.
sorry, lime green is not very popular ?Greeeennn.... you bought them all...sold out now
I have just received this snorkel in the mail. Your description of your installation is one of the clearest I have ever read! Really well done! Gives us confidence that we can do it! Thanks!Loganbeere's Iceberg Build
Putting everything back together
The bottom of the inner snorkel piece where it attaches to the intake bulges into the wheel well some making the plastic wheel well not sit flush but after some fiddling around and tightening everything it all lined up
Test fitting the outer snorkel piece
Added some padding where the snorkel could potentially rub on the FJ to prevent damage to the factory paint over time![]()
Installation completed. Took it for a test drive and nothing fell apart so I think we are good.
MY IMPRESSION OF THIS SNORKEL:
The snorkel feels very sturdy and the fit was really good after it was all said and done. I can grab the snorkel and rock the vehicle side to side and the snorkel does not budge. Instructions were vague and incomplete. I am pretty sure that of all those that installed this snorkel, we all did it a little differently. I only used two of the three brackets to secure the snorkel but it seems pretty secure. Although I had to cut off two brackets inside the fender and trim the fender to get the snorkel to fit, everything can outwardly be returned back to stock. It also doesn't take up valuable space under the hood where I have a second battery mounted.
Skip to continuation of build here (Ghost FJ Build)
Hi Loganbeere! Here's a bit of a time warp! I'm actually in the middle of this snorkel mod and your description has been really helpful! I have the fender positioned back on with the lower snorkel fastened in 3 places! I've dry fitted the top part of the snorkel and it fits good and doesn't interfere with my stock roof rack. I find that the Kaz-english instructions are telling me to anchor the top of the snorkel with a bracket that fits under the "foot" of the roof rack. I'm leery of messing with the roof rack because I have been free from any leaks! Anyway, is it easy to lift just one "foot" of the roof rack or will I need to loosen bolts on all the feet?Loganbeere's Iceberg Build
Your detailed explanation gave me the confidence to tackle the installation of the Offroad Garage snorkel. It was really helpful but I learned a few things on the way.Loganbeere's Iceberg Build
Thanks for the infoYour detailed explanation gave me the confidence to tackle the installation of the Offroad Garage snorkel. It was really helpful but I learned a few things on the way.
Anyway, lots of frustration but lots of satisfaction and the result looks good!
- Sending a lot of US $ to some guy in Kazakhstan is stressful but it did arrive and it was professionally made and packed with good quality. Instructions are on line but very poor quality.
- I have a stock bumper cover (unlike Loganbeere) so I had to remove that, as well.
- You will need many types of trim clips to replace the ones that break!
- Offroad Garage has since solved the antenna problem by moulding a wire into the upper snorkel and leaving a few feet to connect to the antenna tube with a ring terminal. The threaded hole on the tube (where the stock antenna screws in) is a weird thread so I cut off the base of my discarded antenna to use as a bolt. Radio works great!
- The kit has a bracket that attaches with the bolts anchoring the stock roof rack (then I noticed that Loganbeeres build did not have a roof rack at all). I don’t know if lifting one corner of the roof rack feet is even possible but I’m pretty sure that messing with the roof rack connection is a sure fire way to get a leak and a whole new headliner project! In FJ-speak, that’s like asking someone to remove and reinstall their sunroof! Leaks are inevitable! Anyway, I rigged up a temporary bracket until I can figure how to anchor the top end without having to mess with the roof rack bolts.
Thanks! Too bad you're not closer ... of course I overreacted and bought a huge number of clips! More than I could use in 10 lifetimes!Thanks for the info
Mine should arrive any day now...
And... love the zebra look
