The best summary for those deciding to go 35's. In addition to aggressive BMC and some hammering, folding/cutting the pinch weld is necessary, folding & cutting too of the fender (some remove them entirely), removal of mud flaps, etc. I have done what Hayden did and all of the above (except removing the flares), but I still have some body rub, lol.Check out all of the sticky threads that show up first in this wheels and tires section of the forum. There is PLENTY of information on the forums about fitting 35s, but according to this thread, if you want to fit big tires, the basic rule is: keep them as close to the UCA without rubbing as you can. Fitting 35" tires on the FJ is difficult for a few reasons. Body mount chop is 100% necessary. And aftermarket upper control arms are not 100% necessary but make life a lot easier. And lifting the FJ is also a must.
For me to fit 35s with my specific wheel, the TRD 17x7" wheel, this is my setup. I have a 3" lift and 1.25" wheels spacers. If my wheels had different backspacing I wouldn't need wheel spacers but without spacers I rub on my upper control arms at full lock, even with them being tubular aftermarket Total Chaos upper control arms. I also have a body mount chop not only because of the larger tires but also because of the wheel spacers, both of which make it more likely to experience rubbing at the body mount. I actually already had a BMC (body mount chop) when I was running 33" tires with wheel spacers and had to chop the body mount even MORE to get the 35s to rub less. And even then I still had to hammer some spots out of the way and I eventually installed a 1/2" body lift to make it even less likely that I would rub somewhere. And even with all that, I also have to ensure my alignment is done so the castor is pushed all the way forward to around +4 degrees in order to help avoid rubbing even more.
So it has taken a lot of work to get my 35s to fit without rubbing. So if you go this route, good luck. And that is just what I've done to avoid rubbing and be able to still off-road without chewing up my tires. Some folks have too noticeable of a power drop at the pedal from the larger tires and want that "stock feeling" back, so they swap out the differential gears with something with a better gear ratio like 4.56 or 4.88 gears. Or they give their FJ a power boost with a supercharger.
This is why I'm going with 285\75\17 little smaller(34ish) but should hopefully fit without removing all fenders\flap business, I got 285\70\17 to fit with just a BMCThe best summary for those deciding to go 35's. In addition to aggressive BMC and some hammering, folding/cutting the pinch weld is necessary, folding & cutting too of the fender (some remove them entirely), removal of mud flaps, etc. I have done what Hayden did and all of the above (except removing the flares), but I still have some body rub, lol.
I see people say they needed a BMC for 285/70/17 to work however thats what I run and no BMC been on for a year and never rubbed but i haven't been off road heavily with these yet just fields etcThis is why I'm going with 285\75\17 little smaller(34ish) but should hopefully fit without removing all fenders\flap business, I got 285\70\17 to fit with just a BMC
Exactly!I see people say they needed a BMC for 285/70/17 to work however thats what I run and no BMC been on for a year and never rubbed but i haven't been off road heavily with these yet just fields etc
I think it'll vary tire by tire as its so close, with my Good Year Duratrack 285's I could hear them rubbing against the rubber body mount covers(post BMC) at full lock in parking lots but they are pretty aggressive for AT's tires with big side lugs.I see people say they needed a BMC for 285/70/17 to work however thats what I run and no BMC been on for a year and never rubbed but i haven't been off road heavily with these yet just fields etc
I have 1.25" spacers in waiting to put in until I get my OME 3 inch lift. Will I more than likely need BMC to run spacers?I think it'll vary tire by tire as its so close, with my Good Year Duratrack 285's I could hear them rubbing against the rubber body mount covers(post BMC) at full lock in parking lots but they are pretty aggressive for AT's tires with big side lugs.
That is a good question, I don't know jack about spacers besides they could push the tire out(vs stock) which could in theory aggravate the rubbing?I have 1.25" spacers in waiting to put in until I get my OME 3 inch lift. Will I more than likely need BMC to run spacers?
If so ill do that when I rustproof the frame this spring.
I still needed a cab mount chop when I went 285/70r17, something to look out for.guess I will go with 285/70r17's..... and stay stock.
