If I install the All Pro Bumper
how much sag would I get in the front end. Will I need to tweak the suspension. I saw that it weighs 78 lbs. Any advice would be appreciated.
Well, the factory bumper and bumper cover (plastic piece you see) weighs about 30 lbs or so. You are really only adding about 50 lbs.
Your sag will be maybe 1/2 inch i would guess. Your cheapest solution would be to add spacers to the front coil.
Your next cheapest and a BETTER solution would be to replace the front springs with the Old Man Emu 883 coils. Each of these will account for the sag and lift the front end a little higher making the FJ more leveled out.
On an unrelated note, your avatar is scary. If that is you, i apologize. :cheers:
