I installed a 20” Baja Designs LED light on front of my Baja Rack and a few Rigid Industries lights on the sides. I didn’t want to put a hole in the roof for wires. Instead ran positive wires up the backside of the FJ and then ran the negative wires back down and grounded to the interior body.
I used a multi-meter and checked the bolts that go through the roof rack and into the FJ roof. The bolts showed a ground existed. Has anyone grounded to the roof rack? I’m seeing a ground present, are there any issues that I don’t know about? What I’m looking to do is eliminate some of the wires that are running back down the tailgate. The 20” LED bar only draws about six amps and the three Rigid LED’s draw about .5 per light.
Any thoughts on grounding to the roof?
Thanks,
Andrew
Thanks,
Andrew
