I haven't seen a one stop thread on how to go about painting the above mentioned parts. It is all here on the forum, but spread around a bit. I take no credit for any of this, I just wanted to pull it all together for ya'll.
Feel free to add what worked for you and where I may have gone astray in anything. I'll add it up here.
Door Handles:
Easy to remove. Typically cannot remove the black inner portion once the handle is removed from the door; there is one screw that most can't seem to be able to remove (I know I couldn't without completely stripping it). Just mask off the black (at least the portions that will be contacting the inner slide mechanism) and make sure you burnish the tape down so nothing gets under.
Best reference I have found: Handles (Part 1) Handles (Part 2)
Bezel:
Easy to remove. Two screws and two clips to remove. Phillips head for the screws and a flat head works great for popping up the center of the clips, then just pull the clip out. Once you have removed the bezel it is best to remove the black mesh portion from it (cuts down on the amount of masking you have to do). It is pretty straight forward, just a number of screws. The TOYOTA emblem is melted on so you can either attempt to melt it off or just mask it off.
Best reference I have found: Bezel Removal
Bumper wings and lower facia:
Harder than the others but still easy. It is best to remove the front bumper for this and isn't as daunting as you may think. Once you have the bumper off it is just a matter of pulling off clips for the wings and 6 nuts and a few clips for the lower fascia plate. The wings have a rubber seal that should be masked off.
Best reference I have found: Bumper Removal
Soon to come:
Rear bumper wings
Rear bumper lower fascia
Mirrors
Door inserts (considering making an actual wood insert w/ a light natural wood tone)
Painting Technique:
Options:
Sanding + Painting + Clear coat
Wipedown w/ paint thinner or alcohol (let dry) + Painting + Clear coat
Adhesion promoter + Painting + Clear coat
References:
What technique to use?
Work in progress...
Door Handles:
Bezel:
Soon to come:
Rear bumper wings
Mirrors
Painting Technique:
Options:
References:
Work in progress...
