661 - 680 of 682 Posts
KD7GUP Stanwood, WA - Technician
2 Meter mounted on the driver side glove box lid.
Just installed the 2-meter in the FJC, so I guess I'll chime in:
KD0TED
Greater Twin Cities, Minnesota
Forum Name: HOLYSTEEL
Name Mark E.
Call Sign: KC9EKX
Equipment: Searching install options on a 14 FJ
K0MSM - Living in Delaware, got my current callsign when living in Iowa.
Advanced Class since 1981.
FT-8800 mounted in my FJ ("Helios") running to a dual-band magmount, for now.
Sean
My vanity was just granted this morning.
Call sign: K2NAR
Radio: BF-F8HP for now // TM-D710G hopefully soon
Freq: 2m/70cm
Jay N3WWL
Extra class...licensed since 1996
Mobile: Icom IC-V8000 2 meters with 1/4 wave vertical, Midland CB 75-822 with Bandi Mount & Firestick 2 ft. vertical
Home: Flex Radio 6300, Yaesu FT 1000MP - MK-V, Yaesu FT - 102 with FV-102DM VFO & SP - 102 Speaker, Johnson Viking Ranger, National NC-183D, Ameritron AL-82, 120 ft. 600 ohm open wire fed dipole to a Palstar HF-Auto antenna tuner.
First Name: Brian
Callsign: KE0HXD (Tech for now)
Radio: Currently - Yaesu VX8-DR with a mag-mount. Soon to be Kenwood TM-D710A, mounting the antenna to the Expedition One Swing-out upper.
Freq usually on: 2m/70cm
Location: Usually around Denver. Sometimes AZ, KS, NE, NM, SD, UT, WY.
The install will take place with a slew of other stuff - ugh.
Troubleshoot code P0456 "very small" evap system leak.
Install a pair of Baja Designs XL80's on the A-pillars.
Redo the rats-nest of wiring under the hood for the light bar, fog lights, and XL80's.
Remove rocker panel switches and install a Switch Pros 9100.
Rework brackets for a pair of Corbeau Trailcat seats - move seat heater switches to rocker panel.
Install FJVistore headliner shelf.
Install the Kenwood.
Drink a beer.
I've been buying parts & making lists since December, saying when it gets warmer I'll get to it.
Well guess what? It's warmer.
It'll be a multi weekend install. I'm crappy at taking pics of the process, but I've taken enough from the forum. It's time to give something back.
Bob, W1ICW, Milton VT. Finally installing a radio tomorrow in our 09 FJ. Motorola MCS2000 100 watt VHF with a drilled NMO mount 1/4 wave antenna. I prefer the 1/4 wave antennas as they are more tree-proof and cheaper to replace than a 5/8 wave with loading coil. Radio is primarily for 2 meters but a lot of public service frequencies programmed into it as well.
