1 - 20 of 23 Posts
Pros/Cons
Stick'n with 'em/Try something else
I do not have a long term report - but short term
I have the 305/70/16 and to this date and love them
Quiet on the road and look real nice
All I can report right now until I get them in some Mud :clap:
Love my 285/70/17 RT03 MT's.
Pros:
Great traction!
Solid construction
Don't clog much at all
Not too expensive
Good tread wear properties
Cons:
Heavy (there goes the mpg!)
Road Noise (not too bad, though)
Next set I purchase might be an A/T set though, so that I can recoup some mpg's when driving daily commutes. But, by the time these wear out Hankook might come up with a newer design for A/T's that are slightly more aggressive, but not as aggressive as the M/T's. Who knows, tire manufacturers seem to come out with new designs constantly...
http://www.fjcruiserforums.com/forums/wheels-tires/6393-tires-hankook-dynapro-mt-rt03.html
Had mine since Feb. 9,000 miles.
Pro's:
Looks great
Love the side wall design
Great wet road traction
Air these babies down and leave it in 2 wheel drive for most stuff
Solid tire ( Had a nail in one of the lugs and thats where it stopped ). The nail went in to the lug and bent in half
Price (160 a piece)
Great tread wear so far
Awesome off road traction and this M/T does not tear up the trails like some other M/T's, like the BFG and Firestone.
Cons'
MPG's ( expected though with a M/T at around 60lbs a piece )
A bit of road noise ( also expected )
If your looking for an aggressive M/T, this is a mild one
Could be better in sand, but still not bad being they're meant for mud.
All in all, I love this tire and will be buying some more when the time comes
Over 25k miles in a year and a half. I was planning on getting another set when these wear out but it might be a long time from now. They still have lots of tread left. the ride is the same as when I bought them, and the noise level has not changed.
Over all I have been very happy with them.
Does anyone have MPG info on 285s?
With stock 265 Dunlops, I get ~19.5 city/ 21 hwy
With the Kook 285's, I get ~16 city/ 17 hwy (little difference)
They do eat into a tank of fuel, but not too badly...
285/70-R17 RT03 MT
Pros:
Great traction!
Solid construction
Not too expensive
Cons:
Hmmm... Sounds like something I just said...:thinkerg:
I think they call that plagiarism - cut/paste?
I run them on road at 35-36
They feel better then at 39-40 like I had them at before
It's all just personal taste - i would say you should experiment a bit and see what you like
I was wondering what air pressure the rest of you with these tires are running. I am at 40 on the road and 20 off road but I would like to go lower if it is still safe.
I havd hankooks for about 30000 miles took many long trip Ouray, Lake Tahoe, alb NM, Portland Oregon, Pismo Beach CA, San Diego etc
No problem on Highway . great ride expected noise balancing out nicely. The pressure you run depends on your weight and the feel. I back the pressure off when the truck begins to wander some. I run them at about 36 front 34 rear it seems to be a good pressure for my truck. I still have the hankooks in my garage but got a great deal on some BFG's KM2's , these seem to bite the rocks alittle better but I still have no hankook complaints
Now I run 38 front and 36 rear on the BFG's
265-75R16 - 20,000kms and counting...
Pros:
Great traction!
Solid construction
Reasonable tread wear properties
Cons:
Hard to find (North of the Border)
Terrible traction in the snow/cold - to be expected for an MT
Satisfied - don't regret the purchase. Thought I would be doing more "mud" trails.
In retrospect, I would replace them with something that is more available ( ref. expedition travel), narrower and taller.
Ive had mine for about 10k miles. Havent used them off-road much, but on road they are noisy. Holding up pretty well thusfar. Looking forward to seeing them perform in Ouray.
Yours are Noisy ???
Must not have upgraded your stereo yet
I barely hear mine
Maybe after years of throwing grenades in the Army my hearing is suffering a bit
After doing a little research I found that the max pressure on the stock size Hankooks is 80psi. Some of the larger sizes have a max pressure of 50psi. I have pumped mine up over 60psi and will check my mileage on the first leg of my trip to Ouray (200 miles from here to Nashville.) So far around town the higher pressure seems to have little or no affect on the handling of the FJ But if I don't gain any MPG by running this higher pressure I will back it back down to 40 for the rest of the trip.
I will update this as I go.
Scott
41,165 miles on mine - 3,654 off road - about 600 in Moab. I'll replace them before it snows and may sipe them myself for the ice and wet, but I have treated them like crap and they have been great to me. I rotate semi-regularly and run them at 32 for more flotation. My LT265/70R17(32X10.50R17) tire is a 10 ply, where the slightly larger LT285/70R17(33X11.50R17) is an 8 ply tire. I don't know what, if any difference this makes, but I am thrilled with the mileage I have gotten from them.
AWESOME in the sand at 18-20.
1 - 20 of 23 Posts
