I almost replaced the Power Steering pump on our 2007 FJ but first I tried unweighting the front end to make sure that was the problem. When it still turned hard with the front end off the ground, I started working on freeing up the Universal joint at the rack and pinion, which had seized up. I tapped with a hammer and oiled it and it solved the problem. Didn't have to replace the pump which wasn't the problem anyway.
