I am looking to do this to my TomTom Go 720. Do you mind adding some more detail to the install for the electronically inept???
You might want to change that tap to an Add-A-Circuit so that your units will be safely fused.
Layton,I am looking to do this to my TomTom Go 720. Do you mind adding some more detail to the install for the electronically inept???
The cobra has a built in fuse, I kept the existing DC adapter, which already has a fuse. I just used this:You might want to change that tap to an Add-A-Circuit so that your units will be safely fused.
Get fuse taps, and the Radioshack DC adapters shown above.I am looking to do this to my TomTom Go 720. Do you mind adding some more detail to the install for the electronically inept???
HEY.OH count me in, just tell me what parts to pick up before the meet. I am thinking about mounting it on the windshield mirror mount, so gonna run it along the headliner.Layton,
If you need help with that, the next time we get together I can help you wire that up. It won't take long.
Understood. Yes, the DC adapter's fuse will protect your GPS and radar detector. However, I was referring to the power source (wiring) itself coming from the fuse panel to your DC adapter.The cobra has a built in fuse, I kept the existing DC adapter, which already has a fuse. I just used this:
Strip the wires, and solder a fuse tap on the positive end. (Red)
Insert fuse tap, attach ground.
Better yet, you could remove the A-pillar cover to hide both wires (to the Tom-Tom and Cobra).I'd suggest one thing to make it cleaner on the tomtom. you can pop the silver vent thing off by pulling it forward then pop the speaker cover and you can run the wire only showing about 2 inches right at the base of the windshield.
Ahh, I see what you mean. I'll definitely do that this weekend.Understood. Yes, the DC adapter's fuse will protect your GPS and radar detector. However, I was referring to the power source (wiring) itself coming from the fuse panel to your DC adapter.
If there's no protection there and a short-circuit occurs between the fuse panel and the DC adapter, the DC adapter's fuse won't protect the rest of your FJ's downstream electrical system from severe damage and/or possible fire.
Just a suggestion . . . .
Yes to all. Matter of fact, if you choose to do so (which I would recommend), connect your Add-A-Circuit to a "switched" circuit on your fuse panel so that your Tom-Tom automatically turns off and on with the ignition (to prevent accidental battery drain).Question = can I do the following:
1) cut my tom tom power cord before the cig adapter
2) attach tom tom cig cord (that i cut) to Add-A-Circuit
3) plug in Add-A-Circuit plug to fuse panel
This particular fuse slot is not only "switched," but it's also not being used by any other component in the FJ.
Just be mindful of your power cord's polarity (+ and -), and be sure to ground the negative (-) side. Use the manufacturer's recommended fuse size in the Add-A-Circuit. And, use quality automotive electrical crimp connectors.
As shown in the above diagram, the 5th from the left (middle row) just happens to be an empty "switched" fused slot.Thank you very much! As for the "switched" slot how would I know which fuse slot is switched?
x3 or however many more suggested it!Better yet, you could remove the A-pillar cover to hide both wires (to the Tom-Tom and Cobra).
http://www.fjcruiserforums.com/foru...-door-panels-removal-instructions-w-pics.html
