1 - 18 of 18 Posts
Have a warning light on dash. It looks like this (!) but with a line under. I hooked up my diagnostic computer but it says everything is fine ie no codes. This came on right when I started it this morning. It was below freezing last night and this morning so I am wondering if it just a computer problem.
It is a 2009 fj that is very good condition and very well maintained.
Thanks for the help..
Hanzo
:Have you tried hitting it?:lol:
Check your tire psi. Most likely related to cold temps dropping psi in your tires. Make sure that you dont have a nail though.
GL
Kevin
I just checked my tires. All four tires are reading 50psi. They are BFG AT and should be around 65psi cold. I just checked them last week and topped them off. Could the cold be affecting the pressure in my tires? It is 6 below right now.
I have not checked the spare. It has the hard black cover that is frozen with ice and snow. I am going to have to wait for two days, it will warm up then and I will take it off and check it. Right now it is FREEZING!!! But thanks for the help. I will be back on and let you know.
Fun with the kids. Blow up a balloon at room temp and then place it in the frezzer for an hour. Then take it out and let it warm up. Easy demonstration of the effect of tempature on molecules.
Formerly FJ_Marine
Where did you get the 65psi cold number from?
I was wondering the same thing. He must be going off the # on the sidewall of the tire. That is WAY too high. Drop about 30 PSI off that and your teeth won't rattle any more.:lol::cheers:
Does anyone read manuals anymore?
i bet you anything that the spare tire is way too low setting off the light.
Admin
Are you sure it's not the e-brake symbol? (red is the e-brake, orange is the tire one)
Avoid using the e-brake in the cold... the cable can freeze up ***k-stiff.
1 - 18 of 18 Posts
