1 - 6 of 6 Posts
Have you seen this warning light? Was waiting for wife to go for a ride. Was shifting the transfer case to 4HI then 4LO when the FJ was in PARK
A/T P in red. Unengaged Park Warning Light. Doesn't show up in KEY ON warning light check.
Doesn't do it when shifting to 4LO in NEUTRAL. Prob not an issue. I have always shifted to LO range in NEUTRAL.
Might be a problem ........ might not. Worth checking out though.
Reactions: Lee44
Checked the manual. Does say to shift into NEUTRAL before 4LO. No mention of PARK.
■Shifting between H2 and H4
●Reduce your speed to less than 50 mph (80 km/h) and shift the frontwheel
drive control lever from H2 to H4.
If you have trouble shifting in cold weather, reduce your speed or stop the
vehicle.
●If the four-wheel drive indicator does not go off when you shift from H4 to
H2, drive straight ahead while accelerating or decelerating, or drive in
reverse.
■Shifting between H4 and L4
Stop the vehicle, shift the shift lever to N and shift the front-wheel drive control
lever.
■Shifting to L4
VSC is automatically turned off.
■Four-wheel drive usage frequency
You should drive in four-wheel drive for at least 10 miles (16 km) each
month.
This will assure that the front drive components are lubricated.
Discussion Starter #6 (Edited)
(tried to put a :blueblob: in there but it looked squished)
Reactions: bazross
1 - 6 of 6 Posts
