I dont know where to put this. So I'll try here. As the title says, how do I adjust the head lights. I jacked the front up and now I can't see at night. I'm in canada so it's night here like 20 hours a day. Lol
There is a hole behind bracket where it mounts just infront of radiator. Take a long philips head screwdriver and insert down that hole. You should see some gear like teeth. Facing FJ turn to your right for up and to your left for down. Hope it helps.
It's not really a bolt. You have to put a screw driver in the hole behind the headlight as posted by tazman. If you have a 3 inch lift you will most likely have to turn it about 14-17 clicks.
i removed the whole head light. the little clicker that you turn has a 8mm bolt head on it. so instead of trying to turn the clicker, i turned the hole bolt.
