Congrats on the new ride and welcome to the forums!
The Daytime Running Lights are automatic. They come on when you start ur engine.
You can wire in a switch so you can bypass this circuit and turn them off when you want, many people have.
Check this out: http://www.fjcruiserforums.com/foru...54-daytime-running-lights-drl-disconnect.html
Easy mod to do. I did mine in about 1 hour. Just make sure you have the right wires! I double and triple checked before I commenced to cutting. You can buy the switch and all the other stuff you need from a Radio Shack. I use it every day as I have to go on a military base. Some soldering may be required depending on the switch you buy. Good Luck!:bigthumb:
You can also completely disconnect them, very easy to do. took less than 5 minutes for me. the resistor for the DRL is behind the drivers side head light. It is gray plastic once unplugged the DRL's will not come on at all
