1 - 5 of 5 Posts
Hi FJ Fam,
I have a 2007 with 140k, love every second of this truck.
  1. So after a very hot summer with lots of ice cold A/C my heater isn't working this winter.
  2. It blows and I can hear the vent changing.
  3. I was low on coolant (never had engine cooling problems), so I filled it up and I still am not getting hot air.
I am going to burp the system today, and if that doesn't work I will flush the heater core. What is the common heater problems with FJ and my situation?
Thanks for the help!
Tom
Admin
Most common issue would be a completely clogged in-cabin air filter.
Sent from my SM-G950W using Tapatalk
Do you have air movement from the vents and no heat?
Or nothing at all?
Desert Moderator
Air in the cooling system would be my guess.
Classic blown thermostat symptom. Is operating temperature normal, and does it get there as fast as it has in the past?
1 - 5 of 5 Posts
