1 - 18 of 18 Posts
These horns HELLA SUCK!
Bought and installed a pair of Hella horns a few months back.
I spliced the signal from the OEM horn and sent it to the new horns and grounded them separately; I didn’t use the included relay as was recommended by Hella. The result was a new pair of pretty wimpy horns. To my untrained ear, they were not any better than the OEM horn ??
I figured it was my fault for not following Hella’s instructions. “They must not be getting enough juice”, I thought.
Fast-Forward to today. As was recommended on another thread, I re-wired them as per the below diagram:
1124581
Unfortunately, the new wiring made no difference. The horns are still weak and as far as I’m concerned, I got ripped off ???
Dan
Dan
What gauge wire did you use for the "new" installation??
Mean Time Moderator
I bought a pair of Sharp Tones via Amazon. They arrived from India in a very battered secondhand box no idea if they are genuine or not, though the genuine Hellas are made in India. wired them through a relay and they work fine and definately a massive step up from the stock unit. Did you ensure you have a good earth via the mount bolt?
This. It’s been a few years but I remember the part where the ground wire connects to the horn was painted. I honestly don’t remember the brand. I had to grind the paint off where I connected the ground on the horn. The horn worked much better after it was grounded properly.
I traded out the supers for the sharps...sharps are better.....and trey match the FJ.
Hmm, good point. I used 14ga; should that be enough? I just assumes it was ??‍♂
#14 AWG should be fine, assuming that the total length of wiring is reasonably short and that good, low-resistance connections (crimped + soldered) are used at every connection, and that any chassis grounds are clean bare metal and tightly clamped.
Also, there;s no question that the horns were connected in parallel and not in series, and that the polarity is correct?
Discussion Starter #13
...Did you ensure you have a good earth via the mount bolt?
Seems like something I would have done, but I’ll double check just in case. Thanks for the suggestion ??
Dan
Discussion Starter #14
Using the OEM signal to power the horns:
  • spade type connectors soldered to relatively short wires
  • grounds are bolts screwed tightly and directly into the chasis
  • horns wired in parallel
Horns powered directly from battery with OEM signal used as the trigger through the Hella relay:
  • several connections alligator-clipped
  • same grounds as above
  • horns still wired in parallel
it has been suggested that since I got the horns on sale via Woot.com, they may be counterfeit. Hmmm... ?
Seems plausible...
They look cool but they suck. I threw mine in the trash a few years ago. I replaced them with the PIAA superior base horns
I got four Hella supertone but my next horn would be the PIAA Super Bass as I see them retaining their sound intensity longer than Hella.
I also bought the Hella horns from the woot sale a few months back. Mines seemed legit. Took me maybe 10 mines to install and they're definitely WAY loader than the original horns. I doubt that it matters but I used my own spdt relay only because I have a box full of higher quality ones and I'm the guy that always tosses out any wiring/harness that comes with anything and make my own. The tone is definitely european sounding but I dont mind it.
1124881
Dan
Go to
Go to pull apart snag a pair ofc Volvo or Benz bolt plug play add a jumper wire for the second horn under 10 min loud As hell
1 - 18 of 18 Posts
