LIfted my 2007 FJ yesterday didnt have to many issues puttin it all together
I noticed silver/grey grease amounting on the parts near my lower control arm and figured i had a small leak some where. after starting to put every thing together i noticed it was coming from my rack and pinion and the rubber covering over the cv shaft connecting to the rack and pinion, the rubber piece split on the end im not sure if it was from trying to get the new coil overs in. or if i pulled the tie rod out to far when putting it all together. now its leaking pretty bad when i call local auto store they said it was an internal issue and id need to replace my whole rack and pinion, not the rubber end covering...
any help would be aprechiated
thanks :frown
thanks :frown
