So I thought I would save some cash by installing my OME lift and MAF UCAs. I did my research, rented a spring compressor and impact wrench. Found a good thread with pictures detailing how to do the lift installation. I was ready to whip this out in 2-3 hrs. 5 hrs later and frustrated as hell I came inside to get some sleep, as it looks like it's going to be a long day tomorrow.
The breakdown went fairly smoothly. I removed the skid plates, break calipers, sway bar, stock struts and stock UCA. I then re-build the OME struts using the stock strut mount and bushings (I am using the 886OME front springs). I then installed the MAF UCA's and put in the OME struts. At this point I realized the problem, I couldn't get the UCA to seat far enough to get the upper spindle nut onto the UCA. I tried lowering the FJ but the tires won't move sideways to allow the weight of the truck seat the UCA with the spindle.
MY plan tomorrow is to remove the struts then bolt-up the UCA with the spindle and then try to get the OME struts in place.
Any other suggestions will be greatly appreciated.
