1 - 4 of 4 Posts
Recently bought a used 2011 Toyota FJ.
Wanted to upgrade the sound system, bought a new head unit and got it all hooked up. Problem: every time I turn it on, it resets/takes me through the “initial setup” screens/doesn’t save settings. I’m 99.9% (maybe) sure it’s because my wire that’s suppose to go to the accessory wire, is attached to the constant 12v. I did this on purpose just so the head unit would at least play music while I try to solve this problem. I’ve been having a REALLY difficult time finding the accessory wire due to the previous owner making a mess out of the wiring. Anyone know what color it is? Or how I can fix this problem??
fka BLACK HAWK
all you need is constant power. you need a tester to see which fuse is hot all the time then tap into that or add an "Add a fuse"
c/p from metra 71-1761 head unit harness
  • Yellow – 12V Constant
  • Red – 12V Accessory
Had a similar issue. Alpine Head unit would display
Happy New Year!! every time I started the Fj.
I had a loose battery terminal.
Y’all hit the nail on the head!!! I appreciate it!
this is what I did:
like you guys advised, I needed to hook the head unit up to a constant power source. I ended up hooking it up to the vehicles Clock! Which worked perfectly.
gentleman I greatly appreciate your input!
1 - 4 of 4 Posts
