i just go the hi lift jack and i was wondering if anyone knows how i can mount this on the stock roof rack that comes on the fj?
thanks
thanks
Layonnn,Random question. Do you have rock rails or an aftermarket bumper.
My guess is, if the answer is no to these 2 things, there is not much use for a hilift, as there will be no good jack points.....I guess you could still use it for pulling or get that sling for lifting by the wheel (Edit: it is called a lift mate).Layonnn,
Were you going to suggest an alternate mounting method to sliders, or bumpers? Be interested in, if so.
Don't want to hijack.
Unless the OP has steel bumpers or rockrails, there is not much use in having a hi-lift mounted to the vehicle.Layonnn,
Correct Mo. But even with that, you still need to carry a jack stand at all times. IMO it is extremely dangerous to change a tire with the vehicle supported solely by a hi-lift.My guess is, if the answer is no to these 2 things, there is not much use for a hilift, as there will be no good jack points.....I guess you could still use it for pulling or get that sling for lifting by the wheel (Edit: it is called a lift mate).
Hi-Lift Lift-Mate (LM-100) - lift vehicle wheel directly from the wheel | Hi Lift Jack Company
