41 - 42 of 42 Posts
Question on this setup,
I have the same rack as you do, and I like how that mounting looks...
Could I acheive the same thing by just drilling two 1/2 holes through the racks rear uprights and running two bolts through to hold the jack?
Thanks,
webshot
Hi-Lift approximate weight: 30lbs (14 kg). Since you can always use strong bolts/nuts, what I'm worried is the integrity of weld on the upright plates (brackets holding the tubes).
I used a washered nut with 8.8 grade bolt for the lighter side of the Hi-Lift.
On the heavy side (bottom) of the Hi-Lift, I reinforced it with 1" square bar.
Updated picture of the rack.
I like the way you beefed up the heavy side. My overkill mind would force me to do it to the light side too.
41 - 42 of 42 Posts
