So I have 55w 8000k HID's from DDM tuning in halo projectors (H9 bulbs, no wiring harness, they connect directly into the Halogen bulb plugs in the projectors). The problem I am having is that upon initial startup, such as in the morning, both lights will turn on, but then after a second or two, the passenger side bulb will go out. I will turn my lights off, then back on again, and both lights will come on and stay on for good. Also, if I am running my lights on, then turn my car and lights off for say, thirty minutes or so, then come back out and turn the car and lights back on, they will ignite and stay on, no shutting off problems.
I originally had the same ddm 55w ballasts with 6000k H4 bulbs in the reflector housing, with the wiring harness, then I got the projectors, took out the wiring harness, and had 6000k bulbs and connectors from some company like xenontec or something, and those were hooked up again, to the ddm ballasts, and I had zero problems with either of those, no flickering, no shutting off. Now I have 8000k ddm bulbs with ddm connectors hooked up, once more, to the ddm ballasts, but now I am experiencing this issue.
I have had the drivers side do this only once, then never again. It is always the passenger side. What do you guys think the problem is? The bulbs, ballasts, the connectors, or do I need to put the wiring harness in?
Thanks!
Thanks!
