1 - 17 of 17 Posts
Does your hood close easily, but seems a little loose or shaky on trails?
Look underneath the front edge and you will find these.
One half to one turn out each will stiffen up the hood. Not too much or you will make it hard to close and out of alignment. If your hood is crooked against the grille, you can straighten it here also by adjusting the low side only.
A quick turn and it should look like this.
Nice easy fix!!:bigthumb: Good to know:rocker:
FJ Expeditions R Us
Thanks, I add this to my favorites in case I need it!
cheers,
dale
THANK YOU for posting this. My hood has been shaking for a while now and I thought it was from the brace that holds the latch. Mine keeps snapping where it bends. When I re-weld it, the hood stops shaking. But the last time I did it the shaking never went away.
Now it has!!!! :rocker:
Thanks for the info! My hood had a slight shake to it, but with the fix it is solid again. Thanks SonicFJ. Chris
Discussion Starter · #14 ·
Thanks, that is what is great about this forum. Always learning something new. At least this time it does't involve spending $$$.:clap:
Yes, ....well that and the humor. And we all could use a free mod now and then.
all I see is red xxx's dude:rofl::rofl:
Sure thing Jake, had your eyes checked lately?
1 - 17 of 17 Posts
