I like it except for opening the back door. Do you have to completely remove it?[/url][/IMG]![]()
Toyota was showing a modded 2010 FJ at the Abu Dhabi Motor Show last December called the Desert Raider. It had an interesting solution for carrying two Jerry cans.
There was a kind inverted double "J" shaped mount hangin off the roof rack on both sides of the car between the two side windows that don't open and the jerry cans were in holders attached to this bracked just hanging off the sides of the car.
There was around an inch of space between the body and the base of the Jerry can holders with a thick piece of foam or someting similar preventing it from touching the body.
I will try to locate and upload pictures
This one?Toyota was showing a modded 2010 FJ at the Abu Dhabi Motor Show last December called the Desert Raider. It had an interesting solution for carrying two Jerry cans.
Luv that little rack above the spare man thats niceLOD makes a rear bumper with the mounts..
