I don’t have this problem but forum has been complaining about it for a while. Glad you found a solution. Please keep us updated as to how well it is working.
I figured the angle of the stock filler tube was more of a problem than the diameter. When it turns forward to the tank its at a level angle. Maybe why some people have the problem and some dont is because their tube goes slightly downward while others go slightly upward (theory). Maybe when you do a body lift it improves the angle of the filler tube, as some have reported that the problem went away after a lift was done.While filling the tank all of the displaced air must pass through the charcoal canister and then through the air filter located on the left of MordacP's first photo.
My FJ has never had difficulty filling (note it has no lift) so I've wondered why some have had. Perhaps their air filter has become clogged with dirt preventing free passage of the air.
When I installed an aux tank this past summer I inspected my air filter and it was clean.
Some additional thoughts / observations:
The 1" fill pipe is much larger than the amount of fuel that goes in, so that is unlikely to be it.
The small diameter pipe is for shutting the filler nozzle off (a small jet of fuel shoots up it when the tank is filled, to "tickle" the end of the nozzle and trip its shut off before the 1" column of fuel can come up the neck and splash out).
The third pipe (middle sized) that runs up alongside the main filler pipe is the snorkel for the air filter. It has a "head" wrapped around the main pipe at the top (just a baffle to help prevent dirt getting in).
Anyone having difficulty filling their FJ try this experiment:
- remove and inspect/clean the air filter, and then blow air up that snorkel, toward the filler, to make sure there's no dirt clog.
Norm
