1 - 20 of 316 Posts
Very nice job. I am going to wire a similar one into the back for my ARB fridge. I was thinking of drilling the hole in the jack compartment door and running a wire all the way to the battery with a fuse. I usually just purchase an amp cable from walmart (20ft or so). I think I will use the same outlet you used - I like the look better then the Walmart ones I always use.
VTFJC said:
nice job- looks factory, But can you run you refrigerator on it with the engine off? ;)
Actually I was going to inflate my air mattress so I can sleep in it :rolleyes:
I also thought about wiring one to the back of the FJ. Just don't have a reason yet
I wonder what another Toyota outlet would cost? Just the outlet part itself, then install it in the same as this application.
Agreed, I am trying to get the part number from my Toyota parts guy. I like the flip down door on the front one.
My ARB fridge (which is probably the best purchase I made in the last 3 years) will run on AC or DC. In the truck I prefer DC but was going to try AC with the power outlet that comes in the FJC. That was until I found out the outlet doesn't work when the truck is off. Was hoping since it has a switch it would.
Discussion Starter · #12 ·
The Toyota outlet sits into a plastic cradel that locks into the switch plate panel. I'm not sure if you can lock it into place if you were to add it somewhere else. You can see it here.
Could always use a 5 minute epoxy or something. Wont matter since its inside. I like the flip up cap too. Let me know if you get the #
FYI - Used the search and found some info on power outlets!
Wanted to add one myself and found very useful information here.
However, did not like (2) details:
1) tapping into the existing outlet gives you (2) outlets that don't work
when the key is off!
2) I did not want to sacrifice the little cubby hole for an outlet
with a plug sticking in it
Chose the console area for the new outlet and ran the wire to the fuse block.
Had to add about 10-12" onto the Radio Shack outlet to get there.
Included dimensions of outlet location in the pictures. Made sure I missed
molded ribs on the back side and missed the shifter. Left extra wire
under the console to make sure it did not catch the shifter. Used a meter
to find live tap points when key was off. Also used a 1 1/8" bit because
the recommended 1 3/32" is an odd size and I had a 1 1/8"! You will
need to file a small keyway for the anti-rotation rib on the outlet.
Drill your hole 3 5/8" from the front edge and .97" up from the bottom.
Note: The .97" dimension is important for (2) reasons:
Drill too high and you're into the radius on the console, drill too low
and you're into the overhang of the lower console piece.
Room Table Furniture Leather Metal
Box Material property Electronics
Leather Technology Electronic device Rectangle Furniture
Note: The top side of the first (3) open fuse ports on the bottom row are
hot when the key is off. I marked them with a red sharpie.
Machine
Aren't "sticky pads" cool!
Vehicle Car Auto part Center console Gear shift
Last piece of info:
I disconnected the battery for the project. By doing so you will need
to re-calibrate your compass when you are finished. I find that to calibrate
the compass, you need to drive in a "generous" circle, not a tight circle!
1 - 20 of 316 Posts
